Deploying solstice
  • May 1, 2019
  • 22 replies
  • 128 views
ImAMacGuy
Forum|alt.badge.img+23
Has anybody tried deploying solstice? I've tried the Autopkgr deployments and copying the app from a working machine into composer and every time I deploy to another machine, the icon has a line through it saying it's "Not supported on this type of Mac"
  • June 25, 2019
I get the same behavior via autopkg and composer.
Thought it may have been our antivirus messing with it (either in packaging or deployment) but even without it in the picture the issue persists.
ImAMacGuy
  • July 10, 2019
I reached out to Mersive today and they provided me a direct download link to the current client version which worked. I went back and asked for a more general link to download for future versions but I haven't heard back yet. Also, don't mention jamf/mdm deployments.
  • July 10, 2019
You have to modify permissions in my experience. Use the stub installer to download the full .app, put it in a custom package to install in /Applications/Solstice.app and have the post install script do a chown to current user and run a chmod -R 755 on it to be safe. This will at least allow any user to read/launch the app, which I have found to be the issue in the past when packaging for deployment. I am not worried too much about the permissions in my environment, as we have one user per computer, and everyone is authorized to use solstice within our environment.
Also......you don't NEED the solstice app in my experience, you can just airplay to connect to the solstice hub...
  • September 3, 2019
Yup, this worked for me - ended up running an after-command to chmod the Solstice app bundle.
My experience has been that you need to run the solstice app before airplay works, but perhaps that is an artifact of our setup (multiple subnets, etc).
  • September 5, 2019
I'm still having issues with this. I've gone to mersive.com/download and downloaded the zip file. You open it, then it decompresses from that app and puts the actual solstice app on the desktop. I take that file put it in Composer as a new pkg, set root/admin permissions to go to the users application folder however it does not work. Any suggestions?
  • September 5, 2019
Make sure you're not using the SolsticeClientMacWeb.app, that's just a preloader/downloader for the app itself.
Gotta run that and then grab Solstice Client.app from /Applications.
  • September 7, 2019
In addition to what @pitcherj said you have to use the Solstice Client.app which will install on your desktop. What I did was move it to the Applications folder then dragged it into Composer sidebar. It takes a snapshot and then I created a PKG and that worked for me.
  • September 12, 2019
So you took a snapshot before you packaged it? I did all the above steps and then set the root/admin as i was instructed to so it's not assigned to my user account.. but still running into an issue where it deploy
I hardly ever do snapshots, in this case I just did a drag-n-drop of the .app bundle into the left pane of composer.
spalmer
Also, be aware that if the user ever enables the "Automatically Share Audio With Desktop" setting it will prompt for admin credentials to install a Kernel Extension. To avoid this I add a PostInstall script (below), to call their kext installation script embedded in the Solstice app, to my Composer created package as well.
This assumes your package installs the Solstice Client to the main /Applications folder.
## postinstall
chmod ugo+x /Applications/Solstice Client.app/Contents/Resources/SolsticeAudioDeviceInstall.sh
/Applications/Solstice Client.app/Contents/Resources/SolsticeAudioDeviceInstall.sh /Applications/Solstice Client.app/Contents/Resources/SolsticeAudioDevice.kext
The first line makes sure the script SolsticeAudioDeviceInstall.sh is executable because I have had issues in the past where that is not set properly by Solstice.
The second line calls the SolsticeAudioDeviceInstall.sh script with the main argument being the path to the .kext file that needs to be installed.
Haven't had anyone request that (yet), but thanks for posting this - I'll probably run it as a post-install script in Jamf if it ever comes up.
FYI, for those of us following along at home and wanting/needing to whitelist kexts, the TeamIdentifier for Mersive Technologies is 63B5A5WDNG.
donmontalvo
Forum|alt.badge.img+36
  • March 23, 2020
@spalmer Looks like Mersive's dev team neglected to add the proper shebang (#!/bin/bash) to the embedded shell script. Your script is spot on, thanks for sharing. Here's their whole embedded script...
IFS=$''
kextunload /System/Library/Extensions/SolsticeAudioDevice.kext
rm -r /System/Library/Extensions/SolsticeAudioDevice.kext
cp -R $1 /System/Library/Extensions
chmod -R 755 /System/Library/Extensions/SolsticeAudioDevice.kext
chown -R root:wheel /System/Library/Extensions/SolsticeAudioDevice.kext
kextload /System/Library/Extensions/SolsticeAudioDevice.kext
@pitcherj thanks for the KEXT whitelist Team ID, here is the command in case anyone lands on this page:
# codesign -dr - /Applications/Solstice Client.app
Executable=/Applications/Solstice Client.app/Contents/MacOS/SolsticeClient
designated => identifier "com.mersive.solstice.client" and anchor apple generic and certificate 1[field.1.2.840.113635.100.6.2.6] /* exists */ and certificate leaf[field.1.2.840.113635.100.6.1.13] /* exists */ and certificate leaf[subject.OU] = "63B5A5WDNG"
  • January 6, 2021
Looks like Mersive changed the installation method for the Solstice app again. There's an executable in the download /SolsticeClientMacWeb.app/Contents/MacOS/SolsticeClientInstallerMac that installs the client onto the user's desktop, with the correct permissions, so the client now installs via an installer application.
When I package the download up and deploy it, it never appears in the Applications folder. Has anyone found a way to install this from Jamf without having to make a custom package to deploy it to a different directory than /Applications?
jconte
  • March 17, 2022
Has anyone had luck applying settings via script or profile ?  Even just the discovery server would be useful but I cannot figure it out for the life of me.  Any help is appreciated.
Thanks
donmontalvo
  • March 25, 2022
FYI the Mersive Solstice 5.4 release had issues, and they're redoing it (if not done already).
Apparently whoever compiled the source, didn't pay attention, and their UID is the owner once installed.
PS view their installer with Suspicious Package to see what I mean.
  • January 26, 2023
Looks like v 5.5.2 works more like a Mac app should
donmontalvo
  • March 10, 2023
Curious if you're populating the username, server info, etc. If so can you share?
  • March 10, 2023
@jconte We are populating the Discovery server with this postinstall command.
defaults -currentHost write com.mersive.solstice.client "PROFILE/MANUALSDSADDRESS/VALUE" (ip address)
It's been a few years since we've made any changes to the workflow, because we stopped making new Solstice deployments after many users complained about the stability of these for classroom use.
  • March 23, 2023
I'm trying to get the Discovery Server postinstall script to work but haven't had any success.  Tried using
defaults -currentHost write com.mersive.solstice.client "PROFILE/MANUALSDSADDRESS/VALUE" x.x.x.x(IP address)  with no success.  If I run the same command locally on the host computer after installation,  it works and populates the server information, but running it from Jamf does not.
  • March 23, 2023
@Risdal You might try running the command as the logged-in user. I know that Solstice had some unusual permissions requirements when we first started deploying it. We had to change ownership of the client app to make it owned by the user.
  • March 23, 2023
Good point,  I'll have to figure out how to accomplish that with the script.
  • August 15, 2024
Just in case anyone else comes across this. We were able to add the server config by running a script in the install policy (priority set to 'After') containing the following commands (replace $IP_ADDRESS with your server IP):
# Get logged in user ACTIVE_USER=$( echo "show State:/Users/ConsoleUser" | scutil | awk '/Name :/ && ! /loginwindow/ { print $3 }' ) # Get ID of logged in user User_ID=$(id -u "$ACTIVE_USER") launchctl asuser "$User_ID" sudo -u "${ACTIVE_USER}" defaults -currentHost write com.mersive.solstice.client "PROFILE/MANUALSDSADDRESS/TYPE" "String" launchctl asuser "$User_ID" sudo -u "${ACTIVE_USER}" defaults -currentHost write com.mersive.solstice.client "PROFILE/MANUALSDSADDRESS/VALUE" "$IP_ADDRESS"
