I am curretnly having issues with DEPNotify on Catalina Machines.
This was not an issue on High Sierra or Mojave.
All the packages are on a SMB share & are failing mount the share and then install packages.
We are Jamf Pro 10.17.1.
Having read this article https://www.jamf.com/jamf-nation/discussions/34030/policies-failing-operation-not-permitted and applied what I thought would resolve the issue via PPPC still has not fixed the issue.
DEPNotify does start but none of applications are installing.
Scripts, FV2, AD Bind all works.
Just as a proof of concept
1. Ran all my custom events locally they work
2. Did a Web enrollment packages apply
3. Installed packages locally worked
4. Jamf Remote also works
If anyone has had any great success with this please do share how you fixed this.
