Detect If On HotSpot (For Low Data PowerMode)
  • August 19, 2020
  • 39 views
I had it with not knowing if my clients are or not on a hotspot (For Low Data PowerMode) so I wrote something quickly. Now I'll flag certain updates to only download and backup to occur under these conditions.
NETFILE="/Library/Preferences/SystemConfiguration/com.apple.airport.preferences.plist"
CurrentWiFiNetwork=$(networksetup -getairportnetwork en0 | sed "s|^Current Wi-Fi Network: ||")
GetCurrentNetworkSSIDValue()
defaults read "$NETFILE" PreferredOrder | grep "wifi.ssid." | sed 's|.* "wifi.ssid.|wifi.ssid.|;s|",$||;s|"$||' | while read wifi_ssid; do
    WiFiName=$(/usr/libexec/PlistBuddy -c "print :KnownNetworks:$wifi_ssid:SSID" "$NETFILE")
    if [[ "$CurrentWiFiNetwork" == "$WiFiName" ]]; then
        echo "$WiFiName    $wifi_ssid"
        break
done
IsHotSpot()
GetCurrentNetworkSSIDValue | while IFS=$'	' read WiFiName wifi_ssid; do # in the event there is more than one entry which would be weird
    PersonalHotSpot=$(/usr/libexec/PlistBuddy -c "print :KnownNetworks:$wifi_ssid:PersonalHotspot" "$NETFILE")
    echo "$WiFiName    $PersonalHotSpot"
done
IsHotSpot
I broke this up into a couple subroutines so you can pick and choose what you want to do. Enjoy!
  • August 20, 2020
I'm intrigued by this but I'm seeing the following...
Print: Entry, ":KnownNetworks::PersonalHotspot", Does Not Exist
  • August 20, 2020
What operating system are you running @jhuls ? I am running 10.15.6; I have not tested it on any previous OS.
  • August 20, 2020
Same...10.15.6.
To be clear it displays the following...
PCNet wifi.ssid.50434e6574
PCNet is the ssid I'm connected to at the moment. I'm not familiar with the data after that and obviously the message before that seems out of place.
