Device was busy. Will try again.
  • October 15, 2018
  • 24 views
Forum|alt.badge.img+20
Hi Folks,
We are testing our Mojave deployments and while I don't know if this is related to Mojave specifically, I wonder how many of you have run into user level config profiles showing in the management tab as, Device was busy. Will try again?
It appears, this is related to only, User Level config profiles. System level config profiles are deploying without issue. Users can log in fine, but a profile that is intended to be installed at the user level are having issues.
Anyone else seeing this? Are we doing something wrong? Thoughts?
As always, thank you for your replies.
1 reply
  • November 2, 2018
Seeing this "Device was busy. Will try again." under "Status" on a System level Config Profile to a High Sierra 10.13.6 computer. It's not clear what the user is up to at the time of failure.
