Every year we re-image the student laptops. Some of the young students that use laptops. When we click on the User account that these young students the iCloud Prompt pops up. I know there are scripts out there to do this. We even used it in the past but does not seem to work any more. We are using 10.9.5 on these machines. Anyone have any idea what I can do to prevent this iCloud Prompt from popping up without me having to tough a few hundred machines.
Here is what I am using:
"#!/bin/bash"
PLIST="/Library/Users/$ShortName/Library/Preferences/com.apple.SetupAssistant"
sudo defaults write "$PLIST" DidSeeCloudSetup -bool TRUE
sudo defaults write "$PLIST" GestureMovieSeen none
sudo defaults write "$PLIST" DidSeeSyncSetup2 -bool TRUE
sudo defaults write "$PLIST" ShowKeychainSyncBuddyAtLogin -bool FALSE
sudo defaults write "$PLIST" LastSeenCloudProductVersion "15.15.15"
sudo defaults write "$PLIST" SkipFirstLoginOptimization -bool True
I added some lines to the original script we did use in the past that does not seem to work any more.
"#!/bin/bash"
sudo defaults write "$PLIST" DidSeeCloudSetup -bool True
sudo defaults write "$PLIST" LastSeenCloudProductVersion "11.11.11"
I added the "s around the first line because if makes that line larger and does not show the "#"...lol
@jesse.wilson FWIW, with 9.93 there's a profile payload to suppress this.
We found it easier to just sign up for DEP.
May have gone over board...
But so far it has worked...
#Run this script after imaging a machine, this can run as a first run script (at REBOOT), but needs no parameters set if used from the Casper Suite
# Determine OS version
osvers=$(sw_vers -productVersion | awk -F. '{print $2}')
sw_vers=$(sw_vers -productVersion)
# Determine OS build number
sw_build=$(sw_vers -buildVersion)
# Checks first to see if the Mac is running 10.7.0 or higher.
# If so, the script checks the system default user template
# for the presence of the Library/Preferences directory. Once
# found, the iCloud and Diagnostic pop-up settings are set
# to be disabled.
if [[ ${osvers} -ge 7 ]]; then
for USER_TEMPLATE in "/System/Library/User Template"/*
do
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant DidSeeCloudSetup -bool TRUE
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant GestureMovieSeen none
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant LastSeenCloudProductVersion "${sw_vers}"
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant LastSeenBuddyBuildVersion "${sw_build}"
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant DidSeeSyncSetup2 -bool TRUE
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant LastCacheCleanupStillRunning -bool false
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant LastPreLoginTasksPerformedBuild "${sw_build}"
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant LastPreLoginTasksPerformedVersion "${sw_vers}"
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant RunNonInteractive -bool FALSE
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant ShowKeychainSyncBuddyAtLogin -bool FALSE
/usr/bin/defaults write "${USER_TEMPLATE}"/Library/Preferences/com.apple.SetupAssistant SkipFirstLoginOptimization -bool FALSE
done
# If so, the script checks the existing user folders in /Users
# If the directory is not found, it is created and then the
# iCloud and Diagnostic pop-up settings are set to be disabled.
for USER_HOME in /Users/*
do
USER_UID=`basename "${USER_HOME}"`
if [ ! "${USER_UID}" = "Shared" ]; then
    if [ ! -d "${USER_HOME}"/Library/Preferences ]; then
        /bin/mkdir -p "${USER_HOME}"/Library/Preferences
        /usr/sbin/chown "${USER_UID}" "${USER_HOME}"/Library
        /usr/sbin/chown "${USER_UID}" "${USER_HOME}"/Library/Preferences
    if [ -d "${USER_HOME}"/Library/Preferences ]; then
        /usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant DidSeeCloudSetup -bool TRUE
        /usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant GestureMovieSeen none
        /usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant LastSeenCloudProductVersion "${sw_vers}"
        /usr/bin/defaults write "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant LastSeenBuddyBuildVersion "${sw_build}"
        /usr/sbin/chown "${USER_UID}" "${USER_HOME}"/Library/Preferences/com.apple.SetupAssistant.plist
done
@bentoms Where? I can't find this at all though I may be blind.
@bmarks according to this FR it is in the Login Window profile, and it is "Disable Apple ID setup"
@bentoms
Sorry, what do you mean by "FWIW, with 9.93 there's a profile payload to suppress this."
Edited:
Ok first of all I figured out what FWIW means...lol
Second what do you mean by "there's a profile payload to suppress this."
