Disable Spaces/Mission Control for Network Users
  • January 21, 2014
  • 14 replies
  • 179 views
Our school district is piloting the Smarter Balance assessment this spring. One requirement of the testing is that Mission Control/Spaces is disabled. Through the GUI, you do this by going to System Preferences-Keyboard-Shortcuts and unchecking the box for Mission Control. It appears unchecking this box modifies the com.apple.symbolichotkeys (amongst others) preference file. The problem I'm having is that this is a user-level preference and most tips I find online are for local users, not AD users. Anybody have a fairly painless way to do this rather than touching each machine?
Best answer by cbrewer
Setup a configuration profile with a custom payload. Preference domain should be com.apple.symbolichotkeys.
The plist contents should be:
{AppleSymbolicHotKeys={79={enabled=false, value={parameters=[65535, 123, 262144], type=standard}}, 80={enabled=false, value={parameters=[65535, 123, 393216], type=standard}}, 81={enabled=false, value={parameters=[65535, 124, 262144], type=standard}}, 118={enabled=false, value={parameters=[65535, 18, 262144], type=standard}}}}
bentoms
Forum|alt.badge.img+35
  • January 21, 2014
@johnnasset.. Will it now work via MCX?
Forum|alt.badge.img+15
  • January 21, 2014
  • January 21, 2014
Excellent, thanks. I set it as a computer level profile, converted a plist from a machine to xml and uploaded to the JSS. Worked like a charm.
  • January 21, 2014
Mine is User level FWIW.
  • January 21, 2014
Hmm, seems to work fine at computer level too.
cdenesha
  • January 22, 2014
awesome - was dreading tackling this.
  • February 13, 2014
  • February 28, 2014
Here's the original plist contents needed for this. You'll also need to convert it to xml prior to uploading to the jss.
plutil -convert xml1 ~/Desktop/com.apple.symbolichotkeys.plist
<plist version="1.0">
<dict>
    <key>AppleSymbolicHotKeys</key>
    <dict>
        <key>118</key>
        <dict>
            <key>enabled</key>
            <false/>
            <key>value</key>
            <dict>
                <key>parameters</key>
                <array>
                    <integer>65535</integer>
                    <integer>18</integer>
                    <integer>262144</integer>
                </array>
                <key>type</key>
                <string>standard</string>
            </dict>
        </dict>
        <key>79</key>
        <dict>
            <key>enabled</key>
            <false/>
            <key>value</key>
            <dict>
                <array>
                    <integer>123</integer>
                </array>
                <key>type</key>
            </dict>
        </dict>
        <key>80</key>
        <dict>
            <key>enabled</key>
            <false/>
            <key>value</key>
            <dict>
                <array>
                    <integer>393216</integer>
                </array>
                <key>type</key>
            </dict>
        </dict>
        <key>81</key>
        <dict>
            <key>enabled</key>
            <false/>
            <key>value</key>
            <dict>
                <array>
                    <integer>124</integer>
                </array>
                <key>type</key>
            </dict>
        </dict>
    </dict>
</dict>
</plist>
  • March 5, 2014
Can you explain the last step? I was with you until I got to the upload file part of configuration profile. This is the first time I have created one so assume I know nothing...
Thanks in advance,
Katie
  • March 5, 2014
This is not a configuration profile. This is the plist needed for the preference domain after you create a configuration profile in the JSS. Create a new configuration profile and configure custom settings. There you can upload the com.apple.symbolichotkeys plist file.
  • January 27, 2016
Uploaded XML converted Plist
scoped to appropriate devices
Device received the configuration profile successfully
opened up CaSecureBrowser and it still states the need to disable spaces.
Anyone suggestions?
  • April 19, 2016
Anyone have any luck with this and key dict 52, which happens to be "Turn Dock Hiding On/Off" in the Keyboard Pref pane.
Tired defaults write, profile at computer and user levels. Nothing sets it. 10.10.3 workstations.
Thanks
Steve
Thank you very much for this.
  • June 26, 2019
This should be included https://www.jamf.com/jamf-nation/discussions/13713/sbac-secure-browser-7-0-and-disabling-spaces
