Disable Upon Wired Connect
  • February 3, 2016
  • 18 views
Pretty straightforward. I'm trying to enable a disabled upon wired connect setting that does just that. When an Ethernet connection is present it disabled Wifi. Any ideas on the best way to tackle this?
  • February 3, 2016
You will need to test it to ensure it does what you need it to. I've used this in the past and it has worked reasonably well for my needs.
https://jamfnation.jamfsoftware.com/discussion.html?id=1441#responseChild50056
  • February 4, 2016
I've setup 2 network locations , 1 for 'inoffice' (ethernet) and another for 'outofoffice' (WiFi)
Then you can use the command : networksetup -switchlocation [networklocation]
I've scoped a policy using the 'network state change' trigger
cheers
  • February 4, 2016
We needed a way to have only one interface to be active at a time, unless a tech needs to assist.
How it works:
LaunchDaemon has a WatchPath of /Library/Preferences/SystemConfiguration/preferences.plist.old which gets triggered by any Ethernet Change or WiFi change, other things do cause this to be triggered but this was the least triggered method I found. Upon a triggered Watch Path it runs the Script which checks to see if the Ethernet is connected and has an IP and if so it disables the WiFi and if not then Wifi is enabled.
LaunchDaemon Contents: com.network-toggle.plist
<plist version="1.0">
<dict> <key>Label</key> <string>com.uhg.network-toggle</string> <key>ProgramArguments</key> <array> <string>/Library/Scripts/CompanyName/Network-Toggle.sh</string> </array> <key>AbandonProcessGroup</key> <true/> <key>RunAtLoad</key> <true/> <key>KeepAlive</key> <false/> <key>WatchPaths</key> <array> <string>/Library/Preferences/SystemConfiguration/preferences.plist.old</string> </array>
</dict>
</plist>
Script Contents: Network-Toggle.sh
networkAdapters=$(networksetup -listallnetworkservices | grep -v "Bluetooth" | grep -v "FireWire" | grep -v "asterisk" | grep -v "Thunderbolt Bridge" | grep -v "iPhone" | tr -d "")
NEWLINE="
IFS=$NEWLINE
adapterArray=()
for theAdapter in $networkAdapters
do
adapterCheck=networksetup -getinfo $theAdapter | grep '[0-9]
.[0-9].[0-9].[0-9]*'
if [ "$adapterCheck" != "" ]; then
echo $theAdapter $adapterCheck
adapterArray+=($theAdapter)
done
ethernetCheck=echo ${adapterArray[@]} | grep -i Ethernet
wifiCheck=echo ${adapterArray[@]} | grep -i Wi-Fi
if [ "$ethernetCheck" != "" ] && [ "$wifiCheck" != "" ]; then
/usr/sbin/networksetup -setairportpower en1 off
if [ "$ethernetCheck" == "" ] && [ "$wifiCheck" == "" ]; then
/usr/sbin/networksetup -setairportpower en1 on
For our techs to assist with a device or anyone needing the ability to have both interfaces active at the same time, we have a Self Service item that runs the following script, which gives them a dialog with a 15 Minute timer before the network toggle (WiFi Suppression) is activated again.
Disable Network Toggle 15 Minutes: Disable-Network-Toggle-15MinTimer.sh
DelayInSeconds=""
iconToUseParam="/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/GenericNetworkIcon.icns"
if [ "$4" != "" ] && [ "$DelayInSeconds" == "" ]; then
DelayInSeconds=$4
elif [ "$4" == "" ] && [ "$DelayInSeconds" == "" ]; then
DelayInSeconds=900
/bin/launchctl unload /Library/LaunchDaemons/com.uhg.network-toggle.plist 2> /dev/null
/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType hud -icon "$iconToUseParam" -alignHeading center -title "Network Toggle Disabled" -description "Disable Network Toggle allows for both interfaces to be active at the same time." -timeout "$DelayInSeconds" -countdown -alignCountdown left -button1 "Finished" -lockHUD -windowPosition ur
launchctl load /Library/LaunchDaemons/com.network-toggle.plist
I hope this helps!
