Disabling "Show notifications on lock screen" in system prefs
  • February 5, 2014
  • 13 replies
  • 126 views
I am brainstorming a good way to disable "Show notifications on lock screen" in the notifications section of System Preferences. I would like users to be able to get general notifications if they choose, just not on lock screen. What suggestions do you have? Has anyone had success disabling this specific feature of Notifications?
I would like a solution to this as well. My colleague has been digging and it looks like all the notification preferences are being written to a local sqlite db. I would love to get a solution to this.
  • March 10, 2015
You can do this with the script I wrote in this thread:
Another Discussion
  • March 16, 2015
@matt4836 That's a great script. I'm planning on using it shortly. If i'd like to set certain actions for multiple applications like COM.APPLE.MAIL and COM.APPLE.ICHAT would that require both commands below to be run, or can it be combined into a single command? I don't want to do this for all Apple applications which is why "-e Apple" would not work for me.
modifyNotificationCenter.py -e COM.APPLE.MAIL -C -A -B -S
modifyNotificationCenter.py -e COM.APPLE.ICHAT -C -A -B -S
  • March 16, 2015
That is correct.
  • October 19, 2017
Hi @matt4836 I was checking your script and I tried to use it in Sierra but it does not work. Do you have any other script that I can use for Sierra in order to disable the notification on lock screen? I would appreciate any help.
  • October 19, 2017
@Jason you could do COM.APPLE.* I think
EDIT: I misread this and thought you wanted it for all com.apple. My mistake.
  • January 22, 2019
any update on this for Mojave machines? trying to disable lock screen notifications in Mojave for Slack via Jamf Pro. Would likely deploy it to all apps in the long run.
  • January 22, 2019
I've had success with the following script. This seems to work on the first run only. The flag value is a bit different on 10.14 and if the user re-enables the notification, the script might not work as expected the second run. YMMV.
#Populating variables for OS Major and Minor Version
osvers_major=$(sw_vers -productVersion | awk -F. '{print $1}')
osvers_minor=$(sw_vers -productVersion | awk -F. '{print $2}')
IFS=$'
user=$(/usr/bin/python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
#Location of the notification center preferences plist for the current user
notificationsPLIST="/Users/$user/Library/Preferences/com.apple.ncprefs.plist"
#List of the name of the bundles that need to be configured. Set to your needs.
#bundlesToConfigure=('com.apple.FaceTime' 'com.apple.iCal' 'com.apple.FaceTime' 'com.apple.gamecenter' 'com.apple.mail' 'com.apple.iChat' 'com.apple.reminders' 'com.apple.Safari' 'com.apple.iTunes')
# Get list of all user manipulatable notification center objects
bundlesToConfigure=`defaults read $notificationsPLIST  | grep bundle-id | awk -F " '{print $4}' | grep -v "_SYSTEM_CENTER_"`
#Count of the bundles existing in the plist
apps=`/usr/libexec/PlistBuddy -c "Print :apps" "$notificationsPLIST"`
count=$(echo "$apps" | grep "bundle-id"|wc -l)
#Substracting one to run in a for loop
count=$((count - 1))
change=0
disableNotifcationNonMojave()
for index in $(seq 0 $count); do
    #Getting each bundle id with PlistBuddy
    bundleID=$(/usr/libexec/PlistBuddy -c "Print apps:$index:bundle-id" "$notificationsPLIST");
    #If the name of the current bundle is in our list of bundles to configure
    if [[ "${bundlesToConfigure[*]}" == *"$bundleID"* ]]; then
        flag=`/usr/libexec/PlistBuddy -c "Print apps:$index:flags" "$notificationsPLIST"`
        echo Current value:  $index:$bundleID $flag
        if [ $flag -lt 4096 ]; then
            echo "  Flag is less than 4096.  Adding 4096 to disable notification/preview on lockscreen."
            flag=$((flag + 4096))
            change=1
            sudo -u $user /usr/libexec/PlistBuddy -c "Set :apps:${index}:flags ${flag}" "$notificationsPLIST"
            echo New Value: $index:$bundleID $flag
done
disableNotifcationMojave()
        if [ $flag -lt 12438 ]; then
            echo "  Flag is less than 12438.  Adding 4096 to disable notification/preview on lockscreen."
            change=1
done
if [[ ${osvers_major} -eq 10 ]] && [[ ${osvers_minor} -ge 14 ]]; then
    echo "${osvers_major}.${osvers_minor} Mojave was detected. Applying appropriate values."
    echo "${osvers_major}.${osvers_minor} Non-Mojave was detected. Applying appropriate values."
# Restart notification center to make changes take effect.
if [ $change == 1 ]; then echo "Changes made.  Restarting Notification Center for them to take effect.";killall sighup usernoted;killall sighup NotificationCenter; fi
  • June 6, 2019
@jmariani awesome work on the script!
I've been playing around with it's close doing doing what I need. I was hoping to modify it to just uncheck "Show notifications on lock screen" instead of unchecking "Show notification preview". The different flag numbers don't make this a simple task. Any advise?
  • June 28, 2019
@jmariani thanks for your script, I changed it i bit to better reflect the flag comparison. I now dont have any issues for first or second run.
if [[ "${bundlesToConfigure[]}" == "$bundleID"* ]]; then
flag=/usr/libexec/PlistBuddy -c "Print apps:$index:flags" "$notificationsPLIST"
logger DN Current value: $index:$bundleID $flag
flag1=$(($flag & 4096))
echo $flag1
if [ $flag1 == 0 ]; then
logger DN Flag is on. Adding 4096 to disable notification/preview on lockscreen.
flag=$((flag | 4096))
change=1
logger New Value: $index:$bundleID $flag
done
  • June 28, 2019
  • June 28, 2019
  • July 14, 2020
In case anyone is still looking for a solution to managing macOS notifications outside of a configuration profile check out this GitHub project ncprefs.py. Initial testing looks promising. The only caveat is whether or not you would like to maintain the python dependencies. (hint: there is a solution for this - github.com/macadmins/python)
