Do FEU and FUT still work in 10.13 and 10.14
  • September 20, 2019
  • 6 views
I'm creating a package for the Mitel client and I'm trying to include the server settings for convenience. They're saved in a plist file at the user level under Preferences. I haven't had to do this in a while so I'm not sure if the old way of FEU and FUT still works. What's the best way to do this now?
jmahlman
Both still work with 10.13 and 10.14, just ensure that your DMG format is correct (I suggest just using hfs+ for all just to cover all bases).
It’s probably best to start moving away from using FUT and FEU and use something like outset to do this with a script.
Thanks. I'll look into that.
