I'm creating a package for the Mitel client and I'm trying to include the server settings for convenience. They're saved in a plist file at the user level under Preferences. I haven't had to do this in a while so I'm not sure if the old way of FEU and FUT still works. What's the best way to do this now?
Page 1 / 1
Both still work with 10.13 and 10.14, just ensure that your DMG format is correct (I suggest just using hfs+ for all just to cover all bases).
It’s probably best to start moving away from using FUT and FEU and use something like outset to do this with a script.
Thanks. I'll look into that.
