We updated our servers to 10.10.4 and JSS to 9.73 and for the life of us, cant figure out how to solve this, finally turning the gurus of JAMF Nation
Let me start by saying we are new at JAMF, and sure we are making some small or easily fixable mistake, but think we tried as much as we can Google and JAMF Nation, and feel like we are at a point where we need help...
All our applications are stored within CasperShare/Packages, but for some reason when a policy is pushed, for example the 10.10.4 update policy, it reaches out to /CasperShare/ only and then comes back as file not found...
going to /CasperShare/Filename.dmg gives 404 error - /CasperShare/Packages/Filename.dmg downloads fine.
So I moved filename.dmg from /Packages/ to /CasperShare/ and bam! it worked!
Now we would move all our files out of Packages to CasperShare BUT in CasperAdmin, if we add FileName2.dmg, that automatically gets dropped into Packages folder by default.
So we thought why not create a symbolic link from Packages to CasperShare, but when we do that, we get a error message every time we launch CasperAdmin... it says Packages does not have correct permissions.
and thats where I have been banging my head for the last 2 days now!
Any help would be appreciated.
