Dual OS management in single machine
  • December 24, 2012
  • 5 replies
  • 28 views
Can anyone let me know how to handle two OS (Snow Leopard/Lion/M Lion) in single machine?
I am running the recon on either of OS the details of another OS is getting overwritten.
Please help.
Regards,
Anil
kitzy
  • December 24, 2012
I don't know that there's a way around this currently. The inventory record is based of the MAC address of the machine, and since both OSs are running on the same hardware, they'll both have the same MAC address, hence the overwriting.
I've heard that in version 9, the records will be based on a UUID instead of MAC address, which should change this behavior. We won't know for sure until the initial release though.
  • December 24, 2012
Not sure switching to UDID will help as it's tied to the hardware, just like the MAC address.
To confirm, I reloaded a MBP5,2 with two partitions. Its UDID is the same on both partitions.
We have a few machines with two partitions floating around here as well. There is also the problem of policy execution (it runs on one partition, but when booted to the other, it won't as it already ran).
kitzy
  • December 24, 2012
Ahh, good point. The UUID is also tied to the hardware, so that won't really change anything.
  • December 26, 2012
Try recording the MAC address as a removable MAC? That ought to prevent either system from "claiming it".
  • December 27, 2012
How do we do that? any configurations needs to be changed?
