Gents,
I'm taking this back on list because there may be others in the community
that would benefit from this discussion.
To Recap, there are two questions: how to use custom triggers and how to
create dummy receipts.
To use a custom trigger there are two things to do:
1. Create a policy and in the General tab, choose "other (Manually specify
the run at action in this field) -->" from the "Triggered by:" drop down
menu and enter your custom trigger in the text field next to this drop down
menu. I use Apple-esque run-together phrases with caps, such as
"memberAccountingComputerGroup" for my custom triggers. I'm not sure what
the upper limit is for custom trigger length, but I haven't hit it yet, and
I like to be descriptive with my triggers.
Re: "Dummy receipts"
The so-called "dummy receipt" is a receipt from a payload-free package. I
create empty prebuilt Apple .pkg files using Composer like so...
1. Create an empty folder with the same name as your intended package (and
receipt) in /Applications/The Casper Suite/Temp/ (see attachment "Picture
1.png")
2. Open Composer, choose this prebuilt package and save it as an Apple .pkg.
(see attachment "Picture 2.png")
Some may find that using these "dummy receipts" creates clutter, but if you
integrate the concept into your workflows, document your work, and maintain
clear and consistent policies (in the general sense, not Casper Policies)
and naming conventions, use of receipts in this way can be a very efficient
and effective method to extend your management capabilities.
Miles A. Leacy IV
? Certified System Administrator 10.4
? Certified Technical Coordinator 10.5
? Certified Trainer
Certified Casper Administrator
voice: 1-347-277-7321
miles.leacy at themacadmin.com
www.themacadmin.com
