We use DEP for setting up computers that come out-of-the-box, but as of El Capitan (and our upgrade to 9.81) there is a long delay between when the DEP server acknowledges that a Mac should be enrolled in Casper, gets the jamf binary, and executes the enrollment event which light-images the machine.
If you go to the computer (which is listed as DEP - serial) in Casper and select history -> management history, there is one pending command:
InstallApplication Device was busy. Will try again. x minutes ago
The machine at this point doesn't have the management framework installed/jamf binary. On a reboot, the machine does enroll. It will also enroll itself after what is usually a long period of waiting. Has anyone else experienced this or circumvented it?
I am wondering what is causing the computer to think that it is busy, since this did not occur with Yosemite.
