I know you used to be able to run a simple rm -r (user)/.Trash command to empty the trash, but that doesn't seem to be the case in El Capitan and newer - you're supposed to drag all the files in the Trash to the terminal window and then run the command.
Is there some way to automate that process so I could include it in a general first aid Self Service policy?
