Enable Okta Extension for Safari
  • Nov 26, 2021 8:26 AM UTC
  • 6 replies
  • 191 views
Steven_Xu
spent 2 hours to figured out how to enable Okta extension for Safari, post it here if someone need it.
#!/bin/zsh # Safari Extensions File Path(my is macos 11.6): # ~/Library/Containers/com.apple.Safari/Data/Library/Safari/WebExtensions/Extensions.plist username=`/bin/ls -l /dev/console | /usr/bin/awk '{ print $3 }'` cd /Users/$username/Library/Containers/com.apple.Safari/Data/Library/Safari/WebExtensions/ enabled=$(plutil -extract "okta\\.ExtensionLauncher\\.Extension\\.WebExtension (B7F62B65BN)".Enabled raw Extensions.plist) if [ "$enabled" = "false" ]; then plutil -replace "okta\\.ExtensionLauncher\\.Extension\\.WebExtension (B7F62B65BN)".Enabled -bool "Yes" Extensions.plist jamf displayMessage -message "Okta Extension is enabled for Safari, please quit and reopen Safari." else echo "Okta Extension already enabled." fi
  • Nov 26, 2021 11:07 AM UTC
Click Open Safari in the separate window. Enable the extension by navigating to Safari > Preferences > Extensions in your toolbar at the top left corner of your screen and checking the box for the Okta Extension App. Sign into the Okta End-User Dashboard to complete the setup.
alaskasworld
Steven_Xu
  • Dec 3, 2021 6:27 AM UTC
@Rowan45 you are right, we can manually enable it. but for hundreds of computers we need a better solution.
eatkins
  • Oct 20, 2022 5:58 PM UTC
You sir, have done this world a great favor.
iseeetray
  • Oct 25, 2022 3:34 PM UTC
Does this still work on Monterey? When running as script from terminal it works, but after uploading to Jamf and executing a policy it returns an error: "CFURLCopyResourcePropertyForKey failed because it was passed a URL which has no scheme"
Steven_Xu
  • Mar 24, 2023 11:24 AM UTC
it should work, maybe you need full disk access to run the script from jamf policy, the Safari folder is protected by SIP.
https://lapcatsoftware.com/articles/containers.html
iseeetray
  • Mar 28, 2023 8:07 PM UTC
Worked like a charm, thanks Steven
