Enrolling with Management Server Failed error
  • January 13, 2026
  • 11 replies
  • 63 views
Your enrollment Profile MAY have expired. Try loading a new enrollment profile.
I am not sure what to do with this. It is happening immediately following a reset and check in with Jamf. Any assistance is appreciated.
h1431532403240
  • January 14, 2026
Hi JPost,
The "Enrolling with Management Server Failed" error with the message "Your enrollment Profile MAY have expired" can be caused by several factors. Here's a systematic approach to troubleshoot this issue:
Step 1: Check Certificates and Tokens in Jamf Pro
First, verify that all your certificates and tokens are valid:
  1. MDM Push Certificate: Go to Settings > Global > Push Certificates and check if the MDM Push Notification Certificate is expired. If expired or expiring soon, renew it immediately.
  2. Automated Device Enrollment Token: Go to Settings > Global > Automated Device Enrollment and verify the token isn't expired. If there's an error or it's expired, download a new token from Apple Business Manager/Apple School Manager and upload it to Jamf Pro.
Step 2: Verify Device Assignment
  • In Apple Business Manager/Apple School Manager, confirm the device is assigned to your Jamf Pro MDM server
  • In Jamf Pro, verify the device is assigned to a PreStage Enrollment (check Computers > PreStage Enrollments > Scope)
Step 3: Check the APSD Keychain (Common Fix)
If the device has been sitting for a while or the image is older, the local APNS certificate may have expired. Run this command to check:
/usr/bin/security find-certificate -a -p -Z /Library/Keychains/apsd.keychain | /usr/bin/openssl x509 -noout -enddate | cut -f2 -d=
If the date is in the past, delete the keychain and reboot:
sudo rm /Library/Keychains/apsd.keychain
sudo reboot
Step 4: Re-sync with ABM/ASM
Try unassigning and reassigning the device in Apple Business Manager:
  1. Go to ABM/ASM and unassign the device from your MDM server
  2. Wait 10 minutes
  3. Reassign the device to your Jamf Pro MDM server
  4. In Jamf Pro, verify the device appears in Automated Device Enrollment
Step 5: Force Enrollment Renewal
If the device is already past Setup Assistant, try:
sudo profiles renew -type enrollment
Step 6: Last Resort - Erase and Re-enroll
If none of the above works:
  • For Macs with Apple Silicon or T2 chip: Go to System Settings > General > Transfer or Reset > Erase All Content and Settings
  • Then go through Setup Assistant again
Additional Checks:
  • Verify all required network ports are open for Apple services
  • Test enrollment on an unfiltered network (mobile hotspot) to rule out firewall issues
  • Check if any Enrollment Customization in your PreStage is causing issues (try creating a simple PreStage without customization)
References:
Let me know what you find and we can troubleshoot further!
  • January 14, 2026
Those things all check out from what I see. I do see how unassigning and reassigning a device in ABM would help in this situation. The device was auto enrolling fine previously
This seems to be an automated response.
h1431532403240
  • January 14, 2026
Not an automated response – apologies if it read that way.
Since the device was enrolling fine before the reset, the ABM reassignment steps don't apply here. You're right to question that.
This sounds like the apsd.keychain got corrupted during the reset. Can you check the certificate date on the affected Mac?
If it's expired or the command fails, delete it and reboot:
sudo reboot
Then retry enrollment. Let me know what you find.
  • January 14, 2026
Keychain shows Jan 13 19:30:58 2027 GMT
h1431532403240
  • January 14, 2026
Thanks for checking – the keychain is valid, so that's not the issue.
A few follow-up questions:
  • What type of reset was done? (Erase All Content and Settings, or just a jamf removeFramework?)
  • Is there an existing MDM profile still on the device? Check System Settings > General > Device Management
  • What's the exact error message you see during enrollment?
  • Are you on a corporate network with any SSL inspection or firewall filtering?
If there's a stuck MDM profile, that's likely blocking the new enrollment.
  • January 14, 2026
  • Reset - Erase All Content and Settings
  • No Existing MDM profile is on the device as I ran a sudo profile renew -type enrollment and got: Error: DEP enrollment failed: No Device Enrollment Configuration was found for this computer.
  • Error Message while in the MAC Setup screen when it determines the device is a managed SN.
    Enrolling with Management Server Failed. Your enrollment Profile may have expired. Try downloading a new enrollment profile.
  • No I work from Home and have imaged here before. In fact I do most all my testing at my residence for Mac.
Should I need to be on a hardwired connection? I have recently moved my desk and using wifi for this Device. However I am connecting to a 5G (wifi) gb router.
When I hit this error in the setup. My Mac still shows up in Jamf Pro but at DEP - SN
It also does show up with a Jamf Pro Computer ID and Management ID but shows as not Managed. It does show my Enrollment Method as PreStage Enrollment and the config that it is assigned to.
  • January 14, 2026
Also created a new vanilla Pre-stage enrollment with just the General details but no Enrollment Customization and got the same error.
  • January 14, 2026
Also tried off my network using a Hotspot on my phone.
h1431532403240
  • January 14, 2026
Thanks for the detailed info – that rules out a lot of the usual suspects.
The fact that profiles renew -type enrollment says "No Device Enrollment Configuration was found" after an Erase is strange. The device should be pulling its ADE config from Apple's servers at that point.
Since you've already ruled out network (hotspot test) and PreStage customization issues, I'd check:
  1. In Jamf Pro, go to Settings > Global > Automated Device Enrollment and verify your token shows no errors or warnings
  2. Under your PreStage, check the Certificates section – if there's an anchor certificate listed and you're on Jamf Cloud, try removing it
  3. Look at the device record in Jamf Pro – under Management, what does "MDM Capable Users" show?
Also, what Jamf Pro version are you on? And is this happening on just this one Mac or multiple devices?
At this point this may warrant a Jamf Support ticket if the above checks out fine.
  • January 14, 2026
  1. Automation Token generated 12-9-2025. No error showing in the Global/Automation Device Enrollment section
  2. Non of my PreStage Enrollments have Certs in the Cert section.
  3. MDM Capability: No  (No MDM Capable Users row)
Version of Jamf Pro:
Version
11.23.2-t1767621885710
h1431532403240
  • January 14, 2026
All checks look good on the Jamf Pro side. At this point, I'd recommend opening a Jamf Support ticket – they can review the server-side logs to see exactly where the enrollment handshake is failing.
The "enrollment profile may have expired" error with everything else checking out is unusual and likely needs Jamf to investigate from their end.
