So, to test the CIS Compliance scripts linked to in the presentation, I built a clean Mac with 10.11.6. and ran the scripts unaltered. However I received several errors and when re-running the CIS tool, while some settings were changed, many still fail the test.
Looking at the Terminal output and the logs it looks like the defaults commands are failing (and yes I did run the scripts with sudo). Also a suggestion... Since the scripts seem to be performing the settings only on the Currently logged in user, I would suggest adding a loop that runs the commands on all users as well as all of the Template files.
Just wondering if anyone has had any success with these scripts? It is a huge step forward for me, but until I can get all of the settings to configure correctly, there will still be some work to do.
