Execute Script right after policy finished
  • July 14, 2014
  • 10 replies
  • 32 views
  • 4 replies
I need my policy to finish and after the policy finished I want to call a shell script...let's better say just a line of code.
I've tried "AFTER" and "BEFORE" and also with a sleep-timer within...but it seems that the policy will not complete with the script in it.
Is there a chance to call the script right AFTER (not within the policy) the policy ran?
Thanks & best regards,
Dan
  • 43 replies
  • July 14, 2014
You should be able to create a second policy with a trigger, and have the trigger be the first policy.
dpertschi
Forum|alt.badge.img+19
  • 459 replies
  • July 14, 2014
Have you tried to run your code from the Files and Processes > Execute Command field?
That fires at the end of the policy.
  • 8 replies
  • July 14, 2014
The only way i know to do that is to create a smart group with criteria based on the completed policy (such as a file that is now in place or app now installed) and then create a second policy against that smart group.
  • 1892 replies
  • July 14, 2014
+1 for dpertschi.
If it's a one-liner, no need to manage a script.
  • 4 replies
  • July 15, 2014
Many thanks for your fast reply :)
Basically it is a one liner...but the one liner terminates the user session with osacript :/ so the policy does not complete.
Maybe there will have to be really a second policy.
  • 1892 replies
  • July 16, 2014
If you're trying to jump into the user session you may be running into sandboxd blocking you. Watch Console on a target machine as the policy runs and you may see it happen.
Remember that your policy scripts (and Execute Command field) run with implied sudo. You may need to actually do a script, capture the user, then do a sudo -u $user so that you're killing the user session as the user.
Something like:
#capture the user
$user = `ls -la /dev/console | cut -d " " -f 4`
sudo -u $user run_your_command_as_the_user_here.
Chris_Hafner
  • 1754 replies
  • July 16, 2014
+2 for dpertschi
  • 1007 replies
  • July 16, 2014
create a launch daemon to launch the script and pkg both that and the script in a package, load the launch daemon in the postinstall of the package , then have the script wait for jamf processes to exit so your policy gets a good exit, then let the script log out the user.
  • 478 replies
  • July 16, 2014
*launch agent; daemons run in the root context
  • 4 replies
  • July 17, 2014
I've tried all your suggestions...the result was nearly all the time the same ;)
What I want to do exactly:
1) Run Policy for encryption - ok status gets deferred for user xxx
2) Logout the user to start the encryption
As I get the deferred status immediately, I thought the simple logout does the job...but in reality I have to restart my computer, login and log back out.
Is there another workaround?
