Extension Attribute Help
  • November 9, 2012
  • 43 views
I am trying to create an extension attribute that detects the presence of an installer package cached in the Waiting Room. I can run the script manually in terminal and get a true or false result. When I place the script in the extension attribute, I get no result returned. The script:
if [ -e /Library/Application Support/JAMF/Waiting Room/*.pkg.cache.xml ] then echo "true" else echo "false"
What am I doing wrong?
Best answer by stevewood
Your echo statements need to be like this:
echo "<result>true</result>"
You're missing the <result></result> tags. So your script would be:
then
echo "<result>false</result>"
stevewood
Forum|alt.badge.img+38
  • November 9, 2012
then
  • November 9, 2012
Thank you Steve. That is exactly what I needed!
