Extension attribute not displaying stdout
  • May 12, 2016
  • 32 views
I have a simple extension attribute that's supposed to display an Agent version:
# Check to see if the SentinelOne agent is installed.
# If the agent is installed, report the agent
# version.
printf '<result>'
if result=`/usr/local/bin/sentinelctl version | awk '{print $2 $3}'`; then
  printf "$result"
  printf "Unavailable/Not Installed"
printf '</result>'
When I run this locally on my machine, it works, but running it as an extension attribute doesn't seem to work.
Any suggestions on how to debug this issue?
Best answer by hkabik
Try:
# version.
if [ -f "/usr/local/bin/sentinelctl" ] ; then
    RESULT=$( /usr/local/bin/sentinelctl version | awk '{print $2 $3}' )
    RESULT="not installed"
echo "<result>$RESULT</result>"
  • May 12, 2016
I also tried:
# version.
    RESULT=`sudo /usr/local/bin/sentinelctl version | awk '{print $2 $3}'`
Just to see what happens :)
  • May 12, 2016
Try:
# version.
  • May 13, 2016
Super weird. It works when running script via Policy, but as an extension attribute, it does not.
edit: flushPolicyHistory fixed it.
