Hello all.
Since upgrade to Big Sur, the following EA script seems not to work properly anymore, as it always gives result "Not available". Any idea how to fix this?
apiURL="https://xxx.jamfcloud.com/JSSResource/computers/udid/"
apiUser="xxx"
apiPass="xxx"
MacAdd=$( /usr/sbin/networksetup -getmacaddress en0 | /usr/bin/awk '{ print $3 }' | /usr/bin/sed 's/:/./g' )
udid=$(/usr/sbin/system_profiler SPHardwareDataType | /usr/bin/awk '/Hardware UUID:/ { print $3 }')
siteName=$(/usr/bin/curl -s -u ${apiUser}:${apiPass} "${apiURL}${udid}" | /usr/bin/xpath '/computer/general/site/name[1]/text()' 2>/dev/null)
if [[ $siteName ]]; then
echo "<result>${siteName}</result>"
echo "<result>Not available</result>"
Thank you and best regards Christian
Best answer by dan-snelson
@mucgyver The following appears to be working for us:
# https://jamfnation.jamfsoftware.com/discussion.html?id=15258#responseChild93856
apiURL="https://jamfpro.company.com/JSSResource/computers/udid/"
apiUser="xxx"
apiPass="xxx"
#MacAdd=$( /usr/sbin/networksetup -getmacaddress en0 | /usr/bin/awk '{ print $3 }' | /usr/bin/sed 's/:/./g' )
siteName=$(/usr/bin/curl -H "Accept: application/xml" -sfku ${apiUser}:${apiPass} "${apiURL}${udid}" | /usr/bin/xmllint --format - | /usr/bin/grep -A3 "<site>" | /usr/bin/awk -F'>|<' '/name/{print $3}')
echo "<result>Not Available</result>"
exit 0View original
