Hello All,
One of our departments was granted permission to use FileVault 2 for their whole disk encryption. While would not like to see them do that there is little I can do. That being said I put together some extension attributes for reporting information about the file vault 2 encryption and thought I would share them with everyone. There are five all together ( I kinda jet went crazy once I started, there were 6 at one time). Use the ones you need or find useful. They are attached in the zip file in this email. Feel free to change, or improve them, but if you do please post them back so others can share. If anyone has any questions please let me know.
Sean
Here is a break down of what they are and what they give you, I took the names from the actual fields themselves.
Conversion Direction - Show which direction the encryption is flowing. Forward=Encrypting, Reverse=Decrypting, -none-=Complete. for FileVault 2
Conversion Status - Show if any encryption process is taking place with the response of "Converting" or "Complete" when done.
Encryption Context - Show whether or not FileVault 2 Encryption is present.
Size Hard Drive - Shows (Size Total) of hard drive that will be encrypted in GB. (Use to compare the "FileVault 2 Size Converted" attribute.)
Size Converted - Shows the (Size Converted) of the hard drive that has been converted (encrypted) in GB.
Sean Gallagher
Sr. Platform Engineer
The Children's Hospital of Philadelphia
100 Penn Square East 7th Flr.
Phila, PA. 19107
267-426-2607
