Extension Attributes for SSHD
  • February 8, 2023
  • 6 replies
  • 34 views
Hi all,
I will like the help some help in getting Extension Attributes up to grep SSHD.
/bin/launchctl print-disabled system | grep sshd
com.openssh.sshd => true
Sorry that scripting is new to me.
So the <result>True<result/> or False. Please help.
Best answer by sdagley
@yuenhongtang If you want True when sshd is enabled, and False when not this will do it:
#!/bin/sh # EA to check status for com.openssh.sshd # Returns True if enabled # False if disabled sshdStatus=$(/bin/launchctl print-disabled system | /usr/bin/grep sshd | /usr/bin/grep enabled) if [ -n "$sshdStatus" ]; then result="True" else result="False" fi echo "<result>$result</false>"
sdagley
  • February 8, 2023
  • February 8, 2023
Hi, I tried but result false or true. it returned True.
  • February 8, 2023
Thanks sdagley. I changed abit and it works now.
sshdStatus=$(/bin/launchctl print-disabled system | /usr/bin/grep sshd)
if [[ ${sshdStatus} == *"true"* ]];then
echo "YES, system is true"
result="True"
echo "No"
result="False"
sdagley
  • February 8, 2023
@yuenhongtang Apologies, there was a typo in my original post. Please try the EA script now.
sdagley
  • February 8, 2023
result="True"
echo "No"
result="False"
@yuenhongtang You don't want to have extraneous echo command in an EA. The script in my original post has been corrected, and now returns False when appropriate.
  • February 8, 2023
Wouldn't running /usr/sbin/systemsetup -getremotelogin | /usr/bin/awk '{print $NF}' get the same results and possibly be easier? Not that there's any real problem with using launchctl print-disabled system. Just sort of thinking out loud.
