Extension Attributes not populating
  • August 8, 2022
  • 63 views
Hi all,
Not sure why this is failing. I have an Extension Attribute that will simply not populate and I truly cannot figure out why. This EA runs a script that checks for the existence of a certificate on a custom keychain, then outputs either "Found" or "Not found" accordingly. I have removed proper names for privacy reasons:
#!/bin/bash result=$(security find-certificate -a -c 'certificateName' keychainName.keychain) search='certificateName' if [[ "$result" == *"$search"* ]]; then echo "<result>Certificate Found</result>" else echo "<result>Not found</result>" fi
Running this script on a machine (outside of Jamf) returns the expected result. Once a device updates, the EA stays blank. Any help is super appreciated.
Best answer by Tangentism
Your question is almost word for word the same as.....
Your command results in a lot of data from each certificate it finds whereas you should reduce what you want with grep then pipe to awk such as:
result=$(security find-certificate -a -c 'JSS' /Library/Keychains/System.keychain | grep labl | awk -F'=' '{print $2}')
Then do not quote the right hand string in the if...fi comparison so it looks like:
if [[ "$result" == *$search* ]]; then...
The reason not to quote the right hand string comparison is because using either " or ' will treat the * as a normal character and not a wildcard operator.
Tangentism
  • August 10, 2022
brockwalters
  • September 12, 2022
you don't need grep to awk...
security find-certificate -a -c 'JSS' /Library/Keychains/System.keychain | awk -F '=' '/labl/{print $2}'
