Extensis Connect Fonts deployment
  • August 28, 2023
  • 8 replies
  • 202 views
I have been working on deploying Connect Fonts and wanted to share my experience.
Extensis has tools for installing the plugins.
https://help.extensis.com/hc/en-us/articles/6290207443227
sudo "/Applications/Connect Fonts.app/Contents/Resources/plugin-installer" [ --install-all | --uninstall-all|--uninstall-obsolete]
And more info here.
https://help.extensis.com/hc/en-us/articles/5628781808027-Remotely-deploying-Connect-Fonts-Desktop-Mac
The problem is even after running the plugin-installer command through Jamf, the users were still getting prompted to install the plugins. And since our users are not admins they are not able to install them. Further the users were greeted with a startup wizard part of which prompts them to install plugins.
Also Extensis suggests a method of packaging up their software in their knowledge base. This DOES NOT work since the app and the plugins within the app are quarantined from the DMG they provide.
Here's the script I came up with.
# sudo xattr -cr "/Applications/Connect Fonts.app"
# Removes the quarantine flag recursively from the app.
sudo xattr -dr com.apple.quarantine "/Applications/Connect Fonts.app"
# unsinstalls obsolete plugins from UTC or other apps then installs current plugins
sudo "/Applications/Connect Fonts.app/Contents/Resources/plugin-installer" --uninstall-obsolete
sudo "/Applications/Connect Fonts.app/Contents/Resources/plugin-installer" --uninstall-all
sudo "/Applications/Connect Fonts.app/Contents/Resources/plugin-installer" --install-all
Next I needed to create a script that is triggered by a LaunchAgent in order to set the preferences of the ConnectFonts app for each user logging in.
#xattr -dr com.apple.quarantine "/Applications/Connect Fonts.app"
defaults write com.extensis.SuitcaseFusion SUEnableAutomaticChecks 0
defaults write com.extensis.SuitcaseFusion DocumentTrackingEnabled 0
# defaults write com.extensis.SuitcaseFusion suppressProductivityTips 1
# defaults write com.extensis.SuitcaseFusion google-web-fonts.enabled 0
defaults write com.extensis.SuitcaseFusion showFirstLaunchWizard 0
  • August 28, 2023
(Note that I have some lines commented out that I didn't need. Your deployment may be different.)
  • August 29, 2023
Thanks for this, we do something similar but probably much less effectively.
Are your preference settings now bypassing the wizard completely? Eg. user opens app, signs in and thats all?
Would be great, we still guide users through the setup "next, next, next"
*prompts for plugins to install*, *admin window appears*, cancel (because they are already installed via postinstall script), next, next
Pretty annoying experience for everyone involved
  • August 30, 2023
Agree, pretty annoying experience. I've passed feedback along to Extensis.
And yes, this key will skip the setup wizard completely.
  • August 31, 2023
Hi all, has anyone figured out a way for non-admin users to update/install plugins?  Our users are non-admin, and so can't sudo.  Running script as root will fail, because the command is looking to update config files in the logged in user's library.
  • September 1, 2023
I feel like dropping the below into a the postinstall script works to install plugins, it's what we've been doing.
with 2 considerations though:
- We make sure users have Adobe CC + the apps they use installed first (InDesign, AfterEffects etc)
- The first time launch assistant seems to still prompt that there are "new plugins to install" regardless, but we have users cancel this because they are already installed with the app.
But would test and confirm yourself to be sure
That seems to handle initial deployment (albeit not ideal), still working out best method to have the script available for the users to run on demand after the fact
  • September 1, 2023
Yes see above. I'm running the 2nd script as a LaunchAgent on login. And I can confirm that even though the plugins are installed, users are still prompted. This unfortunately also happens on ANY upgrade, even after running their install command. We are going to have to prompt users to hit "no".
  • September 1, 2023
Here's my LaunchAgent which goes in /Library/LaunchAgents/com.company.connectfontsprefs.plist and calls the script.
<plist version="1.0">
<dict>
<key>Label</key>
<string>com.company.connectfontsprefs.plist</string>
<key>Program</key>
<string>/Library/Scripts/SetConnectFontsPrefs.sh</string>
<key>RunAtLoad</key>
<true/>
</dict>
</plist>
  • November 6, 2023
I have fought to get this working. I managed to get all dialogs to disappear except for the tooltips, which still appear for some users. The proper syntax seems to be the following:
#!/bin/zsh
# Rename the application in case it's still called Suitcase Fusion
mv "/Applications/Suitcase Fusion.app" "/Applications/Connect Fonts.app"
# Unquarantine the application from GateKeeper
# Uninstall obsolete plugins and install new plugins
# Suppress messages and updates
defaults write com.extensis.SuitcaseFusion SUEnableAutomaticChecks -bool NO
defaults write com.extensis.SuitcaseFusion SUAutomaticallyUpdate -bool NO
defaults write com.extensis.SuitcaseFusion SUHasLaunchedBefore -bool YES
defaults write com.extensis.SuitcaseFusion suppressProductivityTips -bool YES
defaults write com.extensis.SuitcaseFusion showFirstLaunchWizard -bool NO
defaults write com.extensis.SuitcaseFusion PluginLastVersionChecked -string "25.0.1.11288"
defaults write com.extensis.SuitcaseFusion SavedEULAHash -string "Tk0iQiltNlNrRLLLErzbb3kAiwTRey5EXj/+ZfLLJiY="
