External JSS Help
Hey,
Just looking for a bit of advice with a clustered JSS and certificates.
Has anyone else seen the following errors and if so how did you fix them?
Downloading required CA certificate(s)… There was an error. Error enrolling computer: Connection failure: “The request timed out.”
We've created a secondary external JSS with a jss.net hostname and an SSL cert.
Then we have an internal JSS with jss.local and a built in cert.
When we change it to .net on both JSS' then we receive the above error when trying to enrol.
Best answer by daz_wallace
Cool, so for the external one, thats pretty much it.
For the internal clients / DNS you've got three choices:
1) Only point internal clients to the internal-only JSS
2) Add both internal IP addresses for both JSS servers into the DNS record and (I believe) the DNS servers should use round-robin to push clients to either JSS.
3) Put an internal Load Balancer between the two JSS servers on the internal DNS to intelligently load balance the connections (this may be overkill for your situation).
The golden rule is that your JSS clients can only talk to a single management URL. No Ifs or Buts. You can do some clever things using the DNS (possibly using CNAMEs) but this is the golden rule.
Good luck!
Darren
daz_wallace
Hi @jonnydford
It looks like you're already doing it but both JSS' will need to respond to the same DNS name to work.
Once these are on the same hostname, you'll also need to change the Management URL in "Management settings" > "Global Management" > "JSS URL".
Finally, you'll also need to regenerate the SSL cert for each server in "Management settings" > "System Settings" > "Apache Tomcat Settings" > "Edit" Button
Once complete, this should work. You will likely need to recreate your quick add packages to use the new URL.
Hope that helps!
Darren
  • May 13, 2015
Thanks a lot, Daz.
Just to clarify, should I then set the DNS to have two DNS A records for jss.net:
jss.net > IP address of internal (.local) JSS
jss.net > internal IP address of external (.net) JSS
daz_wallace
The DNS name you choose will need to be externally resolvable, probably something like "jss.[yourdomain].net" and then you'll need to do something called split DNS.
On your internal DNS, "jss.[yourdomain].net" should resolve to your .local JSS IP address. On your external (Public-facing) DNS, "jss.[yourdomain].net" should resolve to your external IP Address of your external JSS.
Hang on, is both of your clustered Tomcat servers internal only, or externally facing?
Darren
  • May 13, 2015
Ahh, I get you.
One is internal facing only, and the other is both internal and external facing.
daz_wallace
Good luck!
Darren
  • May 13, 2015
Thanks a lot for your help @daz_dar
daz_wallace
No problem!
