Hi, Community!
I need your help. We are using the f5 Big IP Edge client. Now we are thinking about switching to f5 Access. And I have no idea how to pre-configure it. I found this manual on f5 site: https://techdocs.f5.com/kb/en-us/products/big-ip_apm/manuals/related/apm-f5-access-macos-2-0-0/1.html#taskid
And correct me if I'm wrong, we cannot directly craft mobile configs in Jamf. When you are creating a VPN profile from f5 Access, it looks like this in MacOSX settings:
So I decided to try to create it using the Jamf VPN Configuration profiles. But, I can't find how to select "VPN application" in the payload.
So my questions are:
1. Is there any way to config VPN application field from a configuration profile
-OR-
2. How to modify, sign, and enroll custom mobileconfig from JAMF
-OR-
3. How to do this configuration in any other method (clone app configuration somehow?)
Thank you!
I am unable to figure this out too.
