Is anyone using File Vault and also Radius / 802.1x profiles?
I am seeing weird things with trying to do the "Use as Login Window Configuration"
File Vault bypasses this and it wont show up unless you login as the File Vault user then logout.
In a perfect world I would like to use both -
Use as a Login Window configuration
Use Directory Authentication
with file vault enabled.
