This little guy helps you enable FV2. In our workflow, we have laptops with mobile network accounts. We don't want the initial FV provision to be done on the local admin / management account (for obvious reasons).
FVHelper will check and skip account names that match the skipaccounts array ...
it will then prompt users to enable FV ...
it calls the jamf policy (with attached FV config so FV is enabled and key escrow is handled by jamf) ...
then force them to logout, so they can enter their passwords and start the encryption process ...
You can run it on the login trigger and / or via Self Service.
https://github.com/loceee/OSXCasperScripts/tree/master/FVHelper
