Firefox v39 Issues connecting to JSS
Show first post
  • August 3, 2015
Thanks, this fixed it for me as well.
Forum|alt.badge.img+27
  • August 4, 2015
I followed the cipher directions here Configuring Supported Ciphers for Tomcat HTTPS Connections and now systems with 10.5 and older are not able to connect to the JSS and Casper Remote can't be used with them. I suspect this is a limitation in that older versions of Mac OS X don't support the stronger ciphers.
Have others observed this with 10.5 and older devices?
  • September 18, 2015
Thank you so much all, Stonham's solution worked for us too!
