Firewall with Casper connection.
  • July 31, 2015
  • 4 replies
  • 46 views
Forum|alt.badge.img+20
On my enrolled macs if I turn Firewall ON, do i have to turn on any options for casper communication?
will turning ON Firewall mess with JSSConnection? (recurring check-in, login/logout etc...)
Best answer by alexjdale
Here is the script, it also checks for the presence of the Connected Backup application and adds it to the approved application list if it is installed. I run this daily for systems that have the firewall off (based on an extension attribute). I can't feasibly stop an admin from turning the firewall off (that I am aware of) so this is the next best thing.
And yes, there is no communication to the client from the JSS, it's all "pull" from the client. If the client initiates the connection (like downloading a package for a software install) then it won't trip a firewall.
fwStatus=`defaults read /Library/Preferences/com.apple.alf globalstate`
if [ "$fwStatus" == "0" ]; then
    echo "FW off, adding exceptions and enabling"
    /usr/libexec/ApplicationFirewall/socketfilterfw --add "/Applications/Microsoft Lync.app"
    if [ -d "/Applications/Autonomy/Connected Backup/Connected Backup.app" ]; then
        /usr/libexec/ApplicationFirewall/socketfilterfw --add /Library/AgentService/AgentService
        /usr/libexec/ApplicationFirewall/socketfilterfw --add "/Applications/Autonomy/Connected Backup/Connected Backup.app"
    if [ -d "/Applications/Iron Mountain/Connected Backup/Connected Backup.app" ]; then
        /usr/libexec/ApplicationFirewall/socketfilterfw --add "/Applications/Iron Mountain/Connected Backup/Connected Backup.app"
    defaults write /Library/Preferences/com.apple.alf globalstate -int 1
    echo "FW on, exiting"
  • July 31, 2015
No, the native application firewall won't affect JSS communication, the connection is heading outbound from the system. There are no incoming connections from the JSS.
We turn on the firewall for all systems with no issues. If you have any apps that require exceptions (that prompt for approval) you can add them with a script. For example, I add an exception for Lync before I turn on the firewall:
  • July 31, 2015
@alexjdale did you write a script that turns firewall on? If so, what is it?
So the enrolled client communicates outward to the JSS in all its communication, such as when performing recurring check in, logout/login policies etc..?
Software installation via Casper will not be affected with firewall ON? This is not considered inbound connection?
  • July 31, 2015
  • August 2, 2015
thanks @alexjdale , I picked apart your script, removing the approved applications stuff. Also created an extension attribute that when its 0 the inventory display will tell me firewall is OFF or if 1 firewall is ON.
