Focus Issue
  • October 21, 2014
  • 6 replies
  • 51 views
Manage a high school iPad program. We use Focus and it is working amazing for us. Ran into to the following problem:
Student is focused into an app, lost internet connection, unable to un-focus, because the iPad Air is focused cannot turn the Wifi back on.
I have tried everything I can think of, any suggestions?
Best answer by bumbletech
You might want to have one of these handy for iPads:
http://9to5mac.com/2014/01/10/video-connect-your-ipad-to-the-internet-via-ethernet-cable-with-this-easy-hack/
iPads won't connect to wifi until they've been unlocked if it has been restarted, but this will allow it to get a network connection in that state. I use it all the time at my school—it's a real life saver.
  • October 21, 2014
I haven't used Focus except for when I took the CMA class but have you or are you able to power down and power back on?
When you say "lost internet connection", did it lose the SSID?
  • October 21, 2014
  • October 21, 2014
Thanks we even have one of these! I should have thought of it. Thanks.
  • February 4, 2015
Does "connect-your-ipad-to-the-internet-via-ethernet" still work with iOS 8?
  • February 4, 2015
We've run into this issue. If the student has a passcode set on his/her device, you can sometimes get wifi to turn back on through the use of control center. The iPad doesn't refocus until it is unlocked. If you can access control center, we've had success turning wifi off and back on.
  • October 23, 2015
A better solution to being locked into the App and no wifi for Casper Focus: Put the iPad in DFU mode by turning the iPad off completely, holding the home button in as you plug the iPad into the computer: then just update the device through iTunes. If you know the passcode lock when update is complete enter that into the device and then the iPad will let you pick the wireless you want and unlock with no issues as long as the commands are still being sent.
Good Luck!
