Force InPrivate Mode in Edge for iOS
  • Nov 22, 2024 9:24 PM UTC
  • 414 views
We set up Edge using an App Configuration within the Mobile Device App to force InPrivate mode and it was working until the most recent Edge update to version 131.2903.54.
Now when Edge is installed on a newly Jamf enrolled iPad or uninstalled / reinstalled on an existing managed iPad the app immediately closes after opening.
When I removed the configuration to force InPrivate mode the app opens but is not in InPrivate mode which is a requirement for our company.
This is the configuration we were using that no longer works.  Has anyone else run into this issue?
<dict>
<key>InPrivateModeAvailability</key>
<integer>2</integer>
</dict>
AJPinto
  • Nov 24, 2024 1:10 AM UTC
Have you opened a case with Microsoft? It's very possible Microsoft updated something which broke this. If you have not made any changes to your mobileconfig, and have reinstalled the app/OS (never mind its happening on multiple devices) you have for the most part ruled out everything you can control.
  • Jan 22, 2025 8:38 PM UTC
Issue was fixed with Edge version 131.0.2903.145, so it was a Microsoft issue.
