Google Drive File Stream - System extension on Big Sur?
  • December 8, 2020
  • 54 replies
  • 395 views
So we currently deploy the Google Drive File Stream client to our workstations. According to the October changelog the application "supports Big Sur," but in testing our previous policies to preapprove the kernel extension for the app obviously no longer works. The app prompts to install a system extension which must be done by an admin user and then prompts for a reboot as expected with the new behavior but when you log back in and run "systemextensionsctrl list" it still says no system extensions found so we can't get the proper app/team IDs to pre-approve with a JAMF payload.
Anyone else run into this, or just happen to have the proper IDs? Are they the same as the old kernel extension?
coachdnadel
  • December 8, 2020
I am running into the same issue, and I would love to figure out a remedy. I believe the team ID is still the same for File Stream so I don't know why my approved kernel extensions config profile isn't working.
  • December 8, 2020
This is actually happening to us as well, there is some glitch causing this and there is still no KEXT-less version in sight. So GDFS will not work with any M1 macs. The last I heard recently that a fix would not be seen until end of Q2.
My guess is that this issue would get addressed with that release of the KEXT-less GDFS
  • December 8, 2020
@quip_MDavison Try switching from a Kernel Extension to a System Extension payload for your Configuration Profiles.. Big Sur moved to System Extensions.. You may or may not have to enable the particular Allowed System Extension Type
Google Drive Help ... Installed MacOS Big Sur beta, Backup and Sync crashes after login. . If the extension is not enabled, obviously it doesn't start at all. Added by suggestion that also Drive File Stream doesn't work either. Meantime, I've transferred my drive to another system and am using that for aces etm
  • December 9, 2020
@JustDeWon Yeah, that's what we're trying to do. Unfortunately when I install the GDFS app to try to pull the proper system extension IDs instead of what we used for the kext it reports that there arent any system extensions installed on the system at all so I can't get the proper IDs to put in the policy.
To clarify these are intel devices running Big Sur, we haven't deployed any M1 macs yet.
  • December 9, 2020
We're in the same boat. We are using Intel Macs. Previously, I had deployed the kernel extensions config, but I tried to switch to system extensions config with no luck.
Thanks for the information keep sharing such informative post keep suggesting such posT
It is that Big Sur drops support for Kernel Extensions (no matter if Intel or M1). Since Google does not provide a version of GDFS without kext at this moment all we can do is wait for Google to deliver a Big Sur compatible version.
  • December 10, 2020
There appears to be a lot of misleading comments in this thread. Here's where I'm at with my testing...
  • GDFS works on Intel Macs running Big Sur. Allow the kernel extension when prompted and restart through System Preferences > Security & Privacy. If there are standard users install a profile that allows standard users to approve kernel extensions.
  • GDFS does not work on Apple Silicon. I continually get "Drive File Stream encountered an error..." no matter what I try.
Curious what others are seeing as the test. Either way, support is limited right now. Please consider upvoting my feature request for Jamf to add RebuildKernelCache to the MDM restart command. That's the only way to install kernel extensions currently without user interaction.
https://www.jamf.com/jamf-nation/feature-requests/9814/rebuildkernelcache-with-restart-command
  • December 10, 2020
@nstrauss That's unfortunately not the behavior we're seeing. Even when installing the app on an intel macbook with Big Sur without JAMF, users are being prompted to approve a system extension for GDFS, not a kernel extension (unless the apple dialogue box is a liar which is very possible). But after approval no system extension is actually registered with the system (but the app works). Our existing Kernel Extension config profile as well as the System Extension policy we're testing for GDFS have "allow users to approve kernel extensions" enabled but in both cases it does not work on Big Sur, an admin still must manually provide credentials to approve installation.
I've reached out to our Google support rep to see if there's something more to it than the vague "supports Big Sur" in the GDFS changelog from October's version update, they probably have better avenues for support than anything we'd get as the customer but odds are it just doesn't actually support System Extensions yet like a lot of other apps we're encountering during testing.
  • December 10, 2020
@quip_MDavison Yes, the dialog box lies. Apple refers to kernel extensions as system extensions in approval dialog. GDFS contains no system extension. The system is prompting to allow the kernel extension. Yes, this is confusing. No, Apple has not been receptive to that feedback.
Make sure the box for "Allow standard users to approve legacy kernel extensions (macOS 11 or later)" is checked. That feature is only available in Jamf Pro 10.26 I believe and is different than only "Allow users to approve kernel extensions." Also keep in mind that profile must be installed after a Mac is on Big Sur. It can't be preinstalled on Catalina for instance.
Standard users can then allow/approve the kernel extension themselves and restart when prompted. Be sure they restart through prompt in System Preferences > Security & Privacy and not Apple > Restart... as my experience has been the kernel cache is not updated that way.
  • January 7, 2021
What a mess. Finally heard back from Google on this and the official response is that they're working on a version of Drive File Stream that either uses a System Extension or utilizes the new file system API in a way that it doesn't need any type of extension, but don't expect it before the end of 2021. They wanted more info on how/why MDM controls couldn't manage the legacy kext in the meantime, so anyone having similar problems may want to reach out and hopefully this puts a little more fire under their engineering team to not wait a whole year for an update.
Allowing standard users to approve extensions isn't really something we're looking to let them do, and a kludgy "restart the right way or it wont work" situation isn't ideal either as we're already dealing with that when enabling Filevault on enrollment (which still isn't fixed in Big Sur). Guess it's just gonna be a long year of Teamviewer sessions and manually pre-installing affected apps when deploying new workstations.
This has been on the DFS deployment page for a little while:
Update on November 25, 2020: Drive File Stream does not yet support Apple M1 devices.
The team identifier to my knowledge is EQHXZ8M8AV
Our newer devices are going to have this issue, but for right now we are staying far away from Big Sur.
Benedict-J
  • January 15, 2021
Google Drive File Stream release notes updated today: https://support.google.com/a/answer/7577057
Upcoming - April 2021 - Apple M1 Support Windows and macOS: Version 47.0 Google Drive for desktop version 47.0 will support Apple M1 devices Additional bug fixes and performance improvements.
  • January 20, 2021
Does anyone know where I can get version 45? The link still downloads 44.0.14.0
adamhcs
  • February 7, 2021
@Phil.James We had to pull teeth with a vendor to get it. https://dl.google.com/release2/drive-file-stream/V77b7GovDOqrxqaQNq-XCg_45.0.12.0/GoogleDrive.dmg
  • February 8, 2021
They finally updated their download link with version 45. Tested and working great on Big Sur. Thanks!
MacJunior
  • February 8, 2021
@Phil.James did you manage to pre-approve the kernal/system extension of it? I still get the pop up window after installing it!
  • February 9, 2021
No. I still haven't figured it out. After a clean Big Sur install I get the popup. With version 45, I DO get the option to manually approve (didn't get the option with old version)
Here is a screen shot of the mdm config, and the manual approval.
No clue.
MLBZ521
  • February 9, 2021
You cannot completely pre-approve a KEXT on Big Sur as you could on Catalina and older versions. You can only approve it so that the user can then themselves approve it (and then reboot to rebuild the kernel cache). The KEXT pre-approve Config Profile does do something, it just does not provide the same function like it did in Catalina.
  • February 10, 2021
Hi Folks,
This is just my observation, but I think the issue with GDFS or GDfD or whatever the hell Google names it now is an issue with the dfsfuse version (a fork of the osxfuse project). In Google Drive for desktop 45.0.12.0 dfsfuse version is 3.7.8 I believe, which as per the osxfuse release logs does not support Big Sur or even M1 macs. However, osxfuse is update to 4.0.5 which supports both Big Sur and M1 macs, but with a caveat,
The license has changed. Starting with the 4.0.0 release, redistributions bundled with commercial software are not allowed without specific prior written permission. This includes the automated download or installation in the context of commercial software. Please contact Benjamin Fleischer.
source: osxfuse GitHub
So I am guessing that there is some legal stuff needing to be worked out, and Benjamin Fleischer is probably (rightfully) looking to get PAAaaaiiiiID, being that osxfuse has picked up a lot of steam lately with all the file streaming apps on the market now.
Box Drive suffers from the exact same issue.
So until both the above update their osxfuse to 4.0 or later, we still need to suffer.
Hope this helps shed some light on the issue.
  • April 12, 2021
Throwing an update here to anyone who finds it since we just got an update from Google engineering- There's currently a beta version of Google Drive (formerly Google Drive File Stream) that supposedly addresses some of the Big Sur permissions issues, but still requires a lot of kludgy workarounds and privilege escalation. They're still trying to find a way to re-engineer the entire product to not need a kext at all. It's gonna be a while for a true solution.
  • June 15, 2021
Oddly enough I have Google Drive Working in Big Sur with M1, however this does not seem to take for intel Macs on Big Sur, so Odd.
Screenshots below, we also had a separate package that installs the root cert for our org, and a defaults write script to point it to the cert if that helps anyone.
Going to keep working on this for the Intel machines, all works except the bit where only on intel it states "System Extension Blocked" and prompts to "Open Security & Privacy Settings" to approve.
Again, seriously perplexed at why this does not happen on the M1 machines!
Forum|alt.badge.img+15
  • July 14, 2021
In my brief experience with 49.0 on an M1, there is no system extension. The app needs full disk access to network volumes, but that was it. On Intel Macs, 49.0 still uses the com.google.drivefs.filesystems.dfsfuse kernel extension.
TimDearborn
  • August 20, 2021
Any luck at getting Google Drive for Desktop to install on Intel machines without the ""System Extension Blocked" and "Open Security & Privacy Settings" to approve"  window?
I have added the appropriate lines to the System Extensions profile as outlined in this thread and have Google Drive installing without user prompt on M1 machines. I just can't get around the admin user prompt on Intel Machines (running Big Sur).
