So we currently deploy the Google Drive File Stream client to our workstations. According to the October changelog the application "supports Big Sur," but in testing our previous policies to preapprove the kernel extension for the app obviously no longer works. The app prompts to install a system extension which must be done by an admin user and then prompts for a reboot as expected with the new behavior but when you log back in and run "systemextensionsctrl list" it still says no system extensions found so we can't get the proper app/team IDs to pre-approve with a JAMF payload.
Anyone else run into this, or just happen to have the proper IDs? Are they the same as the old kernel extension?
