We have a ticket open with JAMF, but we wanted to check with the community to see if anyone is running JSS behind a proxy server?
If so, has it worked reliably? Any gotchas?
No mention in the KB or admin guide:
Integrating with Apple's Global Service Exchange (GSX)
https://jamfnation.jamfsoftware.com/article.html?id=26
Thanks,
Don
We are running it and no issues experienced.
@jconte That's good to hear. Did you get an exception? Or are you using a service account?
TIA
Don
Yes we did, unauthenticated out to ---> 17.151.129.10 gsxws2.apple.com port 80
Strange, both JAMF and Apple told us GSX traffic is over SSL (https).
The reason I'm asking, we're trying to get approval for the traffic at a client shop.
Don
seems that our exception is open for port 80 only. i would try that to start, I am using flawlessly on JSS 9. Worked same on JSS8 as well
