I have a number of devices that hang at "Checking for Policies" when logging off or rebooting. Has anyone seen this or know how to resolve it?
Hi, I have exactly the same problem. A lot of my iMacs will just hang at Checking Policies. Sometime it will go through after a couple of minutes. Sometime it won't. And when it won't, even I turn off all the policies, the computer will still stuck at checking policies. I have to restart it a couple of times to fix the problem. My account manage send me the following to troubleshoot. You can try it too but I don't think this is a good solution. It shouldn't happen at all. I hardly see Windows stuck at Group Policies.
- Delete computer from JSS Inventory
- Run sudo jamf removeFramework in the computer Terminal (if you lucky enough to log on to the computer eventually)
- After the command, check /Library/Application Support/JAMF/Downloads is empty.
- Re-run QuickAdd on the computer and test your policy again. Good luck!
This worked like a charm, Thanks!
Has anyone else noticed behavior like this? We seem to be getting more and more reports of machines stuck at "checking for policies" as soon as a user initiates login.
