Hello, were in a bad situation here.....started imaging our teachers machines today and all of a sudden MANY of our users are unable to mount their H:(network share) drive on login. We are using the mountnetworkshare.sh in the resource kit and have it set to use kerberos auth. All users DO have a valid kerb ticket, and the particular users that are failing are showing logs as follows.
/usr/sbin/jamf is version 8.52
Executing Policy Mount SMB Home...
Downloading https://kibsdjss.kibsd.org:443//Scripts//MountNetworkShare.sh...
Running Script MountNetworkShare.sh...
Script Exit Code:0
Script Result: Attempting to read SMBHome attribute from user record since the 'share' parameter is blank...
Share determined to be: smb://kibsddata.
Volume name will be created as kibsddata...
Attempting to mount smb smb://kibsddata using cfoster01's kerberos ticket...
Writing out launch agent to /Users/cfoster01/Library/LaunchAgents/com.jamfsoftware.mapdrive.kibsddata.plist
Loading com.jamfsoftware.mapdrive.kibsddata...
The correct AD profile path for this user is actually smb://kibsddata/cfoster01$
Her path was originally smb://kibsd-store/cfoster01$ and i moved the share to a new server(kibsddata) to see if that solved the issue...no luck still incorrectly read
Here is a successful log from a user that IS mounting their network drive.
Script Exit Code:0
Share determined to be: smb://kibsd-store/mlinscheid01$.
Volume name will be created as mlinscheid01$...
Attempting to mount smb smb://kibsd-store/mlinscheid01$ using mlinscheid01's kerberos ticket...
Writing out launch agent to /Users/mlinscheid01/Library/LaunchAgents/com.jamfsoftware.mapdrive.mlinscheid01$.plist
Loading com.jamfsoftware.mapdrive.mlinscheid01$...
has anyone else seen this? we are imaging as I type and the more we get done, the larger the number of machines that aren't mounting their users network drives.......help!
