Help setting up Cascading NetSUS
  • June 19, 2012
  • 7 replies
  • 23 views
I have a master NetSUS which works fine and my clients can get updates from it.
I now want to cascade the updates to a secondary appliance. I have tried following: https://groups.google.com/forum/?fromgroups#!searchin/reposado/cascade/reposado/lokxC7Q50vg/b0O0yOE2C6EJ
but struggling to get it up and running.
Is anyone cascading updates that can help?
so does your edit to the preferences.plist give you the desired results? you should be able to run a repo_sync to verify.
you might want to include other catalogs to mirror, though. as greg said, including just the index-lion-snowleopard-leopard.merged-1_testing.sucatalog catalog will only replicate your test branch of the lion catalog.
  • June 19, 2012
Ok I see, I get that now re catalogs I thought it worked differently. On the client side we have 10.6 and 10.7 in our environment. Just to clarify, am I able to point 10.6 and 10.7 to CatalogURL http://10.30.107.97/content/catalogs/others/index-lion-snowleopard-leopard.merged-1_testing.sucatalog
  • June 19, 2012
" I able to point 10.6 and 10.7 to CatalogURL http://10.30.107.97/content/catalogs/others/index-lion-snowleopard-leopard.merged-1_testing.sucatalog"
Yes, you are able to do that. But that's not Apple's recommended or supported configuration. Apple has separate catalogs for each major OS. You should point your clients at those OS-specific catalogs.
-Greg
bentoms
Forum|alt.badge.img+35
  • June 19, 2012
I thought the approved way for 10.5+ was to use index.sucatalog?
As per http://support.apple.com/kb/HT5240
you can use index.sucatalog if you've configured apache rewrite rules on the server side. apple's sus does that for you as of server 10.6.7 or so. not sure if that's in place with the netsus vm, but i doubt it. you'll have to configure it yourself.
  • June 20, 2012
Thank you all for the info
  • June 20, 2012
If you do configure Apache rewrite rules, make sure you also take into account any branches you may have created.
