My script looks like this:
#!/bin/sh TITLE="Delete EVERYTHING and reinstall macOS" HEADLINE="WARNING!! This will erase EVERYTHING!" DECSCRIPTION1="This will erase ALL content and reinstall this mac." DECSCRIPTION2="This will erase ALL content and reinstall this mac. Are you sure you want to continue?" DECSCRIPTION3="Make sure to connect a power supply!" LOG="/private/tmp/install_mac_os.log" echo "Erase and reinstall macOS" > $LOG power=$(pmset -g batt | head -n 1 | cut -d \\' -f2) echo "Power source: $power" > $LOG HELPER=$(/Library/Application\\ Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -icon /private/tmp/InstallAssistant.icns -title "$TITLE" -heading "$HEADLINE" -alignHeading center -description "$DECSCRIPTION1" -lockHUD -button1 "Cancel" -button2 "REINSTALL" -cancelButton 1 -defaultButton 1) if [[ $HELPER -eq 2 ]]; then HELPER=$(/Library/Application\\ Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -icon /private/tmp/InstallAssistant.icns -title "$TITLE" -heading "$HEADLINE" -alignHeading center -description "$DECSCRIPTION2" -lockHUD -button1 "Cancel" -button2 "YES, DO IT" -cancelButton 1 -defaultButton 1) if [[ $HELPER -eq 2 ]]; then if [[ "$power" != "AC Power" ]]; then HELPER=$(/Library/Application\\ Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -icon /private/tmp/InstallAssistant.icns -title "$TITLE" -heading "$HEADLINE" -alignHeading center -description "$DECSCRIPTION3" -lockHUD -button1 "Ok" -cancelButton 1 -defaultButton 1) fi echo "Ok, we reinstall" >> $LOG else echo "Abort" exit 0 fi else echo "Abort" exit 0 fi open $LOG echo "Setting: do not sleep for 3600 seconds (1 hour)" >> $LOG # Do not sleep for 3600 seconds (1 hour) caffeinate -u -d -t 3600 & echo "Downloading installer..." >> $LOG # Download installer softwareupdate --fetch-full-installer >> $LOG echo "Preparing wipe and reinstall..." >> $LOG # Wipe and reinstall /Applications/Install\\ macOS Monterey.app/Contents/Resources/startosinstall --eraseinstall --agreetolicense --newvolumename 'Macintosh HD' >> $LOG
It works just fine all the way up to the startosinstall command.
Instead of starting the installer command, it open the macOS Monterey installer
As if I rand only the app: /Applications/Install\\ macOS Monterey.app
Are you testing on Intel or M1? If M1, you have to pass credentials to startosinstall. Similar to here: https://community.jamf.com/t5/jamf-pro/macos-installer-script-not-working-for-apple-silicon-m1-macbook/m-p/250876
echo $pass | /Applications/Install macOS Big Sur.app/Contents/Resources/startosinstall --eraseinstall --newvolumename "Macintosh HD" --nointeraction --agreetolicense --forcequitapps --user $user --stdinpass
I'm on intel (though we have a few M1's as well)
Which password should I pass? The mgmt user's?
the command is for both chips (intel and M1)
the credentials are of the user who has the Secure Token
https://support.apple.com/de-de/guide/deployment/dep24dbdcf9e/web
Yes, well I obviously doesn't have it as I'm running as a script 🙁
dummy question, but you don't have an error on the path?
but
/Applications/Install\\ macOS\\ Monterey.app
but
Yes, you are right. Well spotted 🙂
I have now included the user and password, but it still doesn't start. It opens the installer as an application
