Help With Computer Naming Script
  • May 4, 2022
  • 26 views
I've been poking through old threads and came across this thread which helped me create a script that accomplishes most of what I'm trying to do with naming machines. I have a script that works as intended, but there are 2 things I was hoping to change and can't quite figure out the best way to accomplish them.
Firstly, when I run this script it doesn't seem to wait for user input to continue. If I leave the first pop up open for a minute or so, it will automatically go to the next prompt, without receiving input from the end user. Is there a way to conditionally require that the end user has to select "Continue" before the next prompt is shown?
Secondly, is there a way to add particular images/icons to these prompts? As of right now the prompts could be misinterpreted as suspicious with no company logo attached (screenshot below)
Apologies if these questions are a bit rudimentary, I'm fairly new to the scripting process. I've included the full script below, I appreciate any guidance!
#!/bin/sh # Name Your Computer.sh #The user will be notified that we are going to change the name of their computer firstName=$(/usr/bin/osascript << EOD tell application "System Events" activate set AssetTag to text returned of (display dialog "We are running a policy that will rename your machine, press continue to begin the process (this will take 1 minute)." buttons {"Continue"} default button 1) end tell EOD) #The user will input the value of their first name firstName=$(/usr/bin/osascript << EOD tell application "System Events" activate set AssetTag to text returned of (display dialog "What is your first name?" default answer "" buttons {"Continue"} default button 1) end tell EOD) #The user will input the value of their first name lastName=$(/usr/bin/osascript << EOD tell application "System Events" activate set AssetTag to text returned of (display dialog "What is your last name?" default answer "" buttons {"Continue"} default button 1) end tell EOD) #The user will input the value of their first name email=$(/usr/bin/osascript << EOD tell application "System Events" activate set AssetTag to text returned of (display dialog "What is your veda email?" default answer "" buttons {"Continue"} default button 1) end tell EOD) #The user will choose their department from a drop down menu dept=$(/usr/bin/osascript << EOD tell application "System Events" activate set Department to (choose from list {"Corporate", "Delivery", "Marketing", "Sales", "Science", "Success", "Technology"} with title "Departments" with prompt "Please choose your department") end tell EOD) #gets current logged in user getUser=$(ls -l /dev/console | awk '{ print $3 }') #Groups first and last name realName="$firstName $lastName" #Takes the data collected from the user and sets it as the Computer Name and submits the name to the Jamf API deviceName="$realName - Macbook Pro" #Set all the name in all the places /usr/local/bin/jamf setcomputername -name "$deviceName" /usr/local/bin/jamf recon -endUsername "$firstName$lastName" -realname "$realName" -email "$email" -position " " -building "test bldg" -department "$dept" -phone " " -room " "
1 reply
  • May 4, 2022
I was able to get custom images set up, but am still trying to figure out how to wait for user input before the next prompts are given. Updates script below:
#!/bin/sh # Name Your Computer.sh #Get logged in user info loggedInUser=$3 #Icon location brandingImage="/Users/$loggedInUser/Library/Application Support/com.jamfsoftware.selfservice.mac/Documents/Images/brandingimage.png" #The user will be notified that we are going to change the name of their computer firstName=$(/usr/bin/osascript << EOD tell application "System Events" activate set AssetTag to text returned of (display dialog "We are running a policy that will rename your machine, press continue to begin the process (this will take 1 minute)." buttons {"Continue"} default button 1 with icon posix file "$brandingImage") end tell EOD) #The user will input the value of their first name firstName=$(/usr/bin/osascript << EOD tell application "System Events" activate set AssetTag to text returned of (display dialog "What is your first name?" default answer "" buttons {"Continue"} default button 1 with icon posix file "$brandingImage") end tell EOD) #The user will input the value of their first name lastName=$(/usr/bin/osascript << EOD tell application "System Events" activate set AssetTag to text returned of (display dialog "What is your last name?" default answer "" buttons {"Continue"} default button 1 with icon posix file "$brandingImage") end tell EOD) #The user will input the value of their first name email=$(/usr/bin/osascript << EOD tell application "System Events" activate set AssetTag to text returned of (display dialog "What is your veda email?" default answer "" buttons {"Continue"} default button 1 with icon posix file "$brandingImage") end tell EOD) #The user will choose their department from a drop down menu dept=$(/usr/bin/osascript << EOD tell application "System Events" activate set Department to (choose from list {"Corporate", "Delivery", "Marketing", "Sales", "Science", "Success", "Technology"} with title "Departments" with prompt "Please choose your department") end tell EOD) #gets current logged in user getUser=$(ls -l /dev/console | awk '{ print $3 }') #Groups first and last name realName="$firstName $lastName" #Takes the data collected from the user and sets it as the Computer Name and submits the name to the Jamf API deviceName="$realName - Macbook Pro" #Set all the name in all the places /usr/local/bin/jamf setcomputername -name "$deviceName" /usr/local/bin/jamf recon -endUsername "$firstName$lastName" -realname "$realName" -email "$email" -position " " -building "test bldg" -department "$dept" -phone " " -room " "
