Help With Extension Attribute
Hello,
I need to setup a simple extension attribute to display the installed version of Python on our MacBooks. I'm using the following script input, but the display in machine inventory for the extension attribute remains blank. What am I missing? Here is the script:
#!/bin/sh PY=`python --version` echo "<result>$PY</result>" exit 0
That should do it, right?
Any help is appreciated!
Best answer by boberito
For whatever reason the python command doesn't output to stdout so you have to redirect it.
#!/bin/sh PY=$(python --version 2>&1) echo "<result>$PY</result>" exit 0
boberito
Forum|alt.badge.img+22
  • August 24, 2021
  • August 24, 2021
THANK YOU! That did it.
donmontalvo
Forum|alt.badge.img+36
If you need the version number for comparisons:
/usr/bin/python --version 2>&1 | awk '{ print $2 }'
For python 3 opensource:
/usr/local/bin/python3 --version | awk '{print $2}'
Forum|alt.badge.img+31
  • August 25, 2021
This is how I do it
#!/bin/zsh
if results=$(/opt/snowflake/bin/python3 -V | awk '{print $2}')
then echo "<result>${results}</result>"
else echo "<result>false</result>"
This way if it fails you have a `false` value and that data is actionable
donmontalvo
This is how I do it
#!/bin/zsh
Nice, can also pull the major.minor.patch (semver.org), and use a Smart Computer Group to flag any computers that have a python3 version that isn't at the desired version or higher.
For example if you want everyone on 3.9.7 or higher, flag any computers that do not match this regex. This way if someone has a newer version, they don't get rolled back (unless you're enforcing a specific version):
^3\\.9\\.[7-9]|^[4-9]\\.[0-9]\\.[0-9]
