Hide Settings icon in iPads
  • January 19, 2022
  • 4 replies
  • 203 views
DerbyMuseumPete
I'm setting up a number of new iPads and using Jamf Pro.
I've got them configured mostly how I want, but because these will be used in a classroom environment I need to hide the Settings icon to stop people fiddling.
How can I do this?
  • January 19, 2022
The settings app is the only thing that can't be hidden. It's always there, even if you restrict everything. The best you can do is use a config profile to restrict the areas that the users can see/change in there although you can't control everything in there.
DerbyMuseumPete
  • January 19, 2022
Thanks for the quick reply.
Ahh ok, that sucks.... !
Hopefully in an update...
  • February 6, 2022
Good Day @RLRL I am a newbie to JAMF.
Could you please guide me how to Configure a profile which achieves this >> Hiding some items in System settings on iPad. 🙏
  • February 7, 2022
You will need to go to Devices > Configuration Profiles > New Config profile.
The main options you need to go through are the restrictions payload. There's a lot to look through and might take some testing to figure out which of these settings are part of the settings app.
