Hoping someone can help or offer some advice...
As Apple have stated that monolithic system imaging is a thing of the past or at least not supported going forward with High Sierra. I've ran into a few issues with deploying High Sierra to our 200+ mac estate. Because of the firmware updates not being properly applied via monolithic imaging I was advised by our Apple tech engineer to first run the high sierra app store installer so that it pulls down the relevant firmware and to then go ahead with the my usual method which is to NetBoot via Parallels, format the disk and then run through our task sequence applying High Sierra and apps ect...
But unfortunately these users are coming back to me a few days later with their MacBook's locking up and freezing every 5/10 minutes regardless of what app is running.
Any ideas?
