High Sierra update issues
  • June 6, 2018
  • 13 replies
  • 116 views
Set up a policy to push the 10.13.5 update, uploaded the combo .pkg file to our repo so jamf can just prompt the user for its install without bothering them with the App Store process. But some of my test users reported that they already had the 10.13.5 update applied and were still getting the prompt. But I made sure to restrict the policy by telling jamf to only offer it to computers that the App Store flag as needing it. Suggestions?
  • June 7, 2018
Within the policy get it to also do a maintenance > update inventory
Would be my best guess.
  • June 7, 2018
I would set up a smart computer group with the criteria 'Operation System Version', operator 'less than' and value '10.13.5'.
You can limit the 10.13.5 combo patch to specific computer groups and select the one you've just created. Jamf won't bother anyone that's already had the update then.
davidacland
  • June 7, 2018
We update to 10.13.5 using the softwareupdate command instead (pushed via a policy). That way there's nothing to upload to a DP, firmware updates are included (if there are any), and it only applies to computers that need it, so no smart groups or complex scoping needed.
  • June 7, 2018
For us that isn't an option @davidacland but trust me I wish it were the case. In any event I think I've locked down one issue. At some point our users were told to update their macOS via the App Store and for whatever reason the computer didn't check back in with JSS to report its version. I've identified at least three computers running 10.13.5 that JSS thinks they have various flavors of 10.12. What is confusing is the JSS is set to have computers report in every 15 min. Ideas?
davidacland
  • June 7, 2018
I'd suspect an issue with the client's connection to the JSS. Are the affected Macs checking in at all after the upgrade?
If you run a few commands on the client, like jamf recon and jamf checkJSSConnection and jamf manage, that might give you some more info.
  • June 7, 2018
Well your computers do check every 15 minutes whether there are any applicable policies, but I guess they report inventory updates probably once a day or once a week. So it might take a while after the updates are installed before the inventory is updated.
  • June 7, 2018
My last user to get 10.13.5 called me today to run the update MacOS said it required. App Store said it was needed & when checking, it went away. Checking "About The Mac" it had been applied since the system had been rebooted already. Weird bug on Apple's end.
  • June 18, 2018
@davidacland Question for you. The softwareupdate command, if a user is on El Cap will that also force a update all the way to High Sierra or stay within their OS version?
davidacland
  • June 18, 2018
softwareupdate only applies the minor OS updates so should be safe. If you want to be sure, run softwareupdate --list first to see what updates are going to be applied.
  • June 18, 2018
@davidacland Ok, and sorry here for the super noob question, how would I go about running the softwareupdate --list on hundreds of computers? A shell script I assume, then pull the report somehow from JSS?
  • June 18, 2018
In general, I recommend you get used to "control scripts" to manage deployments so you can add some logic to them. Installing packages without validating they are needed or installable leads to all kinds of potential issues.
You'd do this by having two policies: one policy which runs the control script, and then that control script runs a policy with an event trigger once it determines the installation is appropriate for that system. Relying on inventory data works most of the time but there are exceptions for timing (since inventory data is not live) and recon failures.
  • June 18, 2018
Thank you both.
davidacland
  • June 19, 2018
You can probably skip the —install part and just use the inventory collection settings in Jamf to include available software updates (its off by default).
You can then see what updates will be applied in the computers inventory.
I’d only use —list on one Mac running 10.11 to reassure yourself that it isn’t going to upgrade to a newer major macOS release.
