How can I use Jamf Pro to manage inventory and devices for my online textile business?
  • Aug 5, 2025 11:51 AM UTC
  • 113 views
radhikasharma02
Hello, I’m Radhika Sharma, and I manage an online textile business specializing in Jaipuri Print Fabric and Discharge Hand Block Printed Fabric. I’m exploring ways to manage both inventory and Apple devices (like iPads and Macs) used in my business operations using Jamf Pro.
Specifically, I need help with:
  1. Device Management – Setting up Macs/iPads for employees handling stock and orders.
  2. Inventory Management Solutions – Integrating Jamf with inventory software or systems for better tracking and automation.
Any advice on how to effectively use Jamf Pro in a retail or business setting would be greatly appreciated!
Thanks in advance!
mvu
  • Aug 5, 2025 12:26 PM UTC
Have you reached out to Jamf for a demo and more info? Jamf can certainly help with your two bullet points. Jamf intergrates with many solutions, so a call with Jamf can determine how it fits into your current inventory solution.
AJPinto
  • Aug 5, 2025 12:42 PM UTC
I suggest you reach out to Jamfs Sales team. They will have the best answer for you. In short, yes Jamf will have no issues managing your fleet. Jamf has a very robust API, but its down to your inventory management solution on if it supports Jamf’s API but most that I have dealt with do.
