How to best deploy a plist and a script?
  • August 8, 2018
  • 39 views
Am struggling a bit with deploying a plist and script.
What i am trying to achieve is that i deploy the plist in the launchdeamon folder and the script in the scripts folder in a subfolder.
Options i tried:
1. Tried to package it and then deploy it directly in those folders but that doesn't work.
2. Created a DMG and copy it by default in the /Library/Application SupportJamf folder and then move it to the appropiate folders but that also doesn't work.
So the question is, does anyone have a hint on how to do this in a correct way?
In short i want to deploy the .plist in /Library/LaunchDeamons and the script in /Library/Script/Subfolder and then launch the deamon with sudo launchctl load -w /Library/LaunchDaemons/com.company.networkwatcher.plist
When i manually deploy it works nicely but i want to have it scoped by JAMF as a policy as it is a policy for automatic switching between LAN / WIFi.
Thanks,
Dennis
  • August 8, 2018
You can definitely deploy LaunchDaemons and scripts using drag and drop creation Composer, if it's in the correct place on the target but not running I would check the permissions on the plist in Composer, almost every time I have had issues with this it was the permissions set in Composer that were the issue.
  • August 9, 2018
The way i did it is by using a plist to run the Script at load and place it inside LaunchAgents so it runs everytime somebody logged in.
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>Label</key> <string>net.plistname</string> <key>ProgramArguments</key> <array> <string>sh</string> <string>/Library/Scripts/Subfolderscript.sh</string> </array> <key>RunAtLoad</key> <true/> </dict> </plist>
