Hi all
I am using Jamf Pro cloud and Jamf Connect 2.10 version with Azure AD and MFA authentication. I have turned on FIlevault using Jamf connect.
I usually have dual log in, the first log in to decrypt filevault and second log in which is Jamf connect/Azure AD MFA log in
Everything work fine but recently we have received feedback how to bypass Jamf connect login/Azure login in some scenario and user only need to perform local account log in:
1. for instance only ask for Azure/Jamf connect log in if network change
2. Dont ask for Azure/Jamf connect log in if the device is on for last 7 days
Just wonder if anyone ever successfully implemented Jamf connect bypass with some conditions before?
Have seen the configuration profile below to disable Filevault automatic log in
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>DisableFDEAutoLogin</key> <true/> </dict> </plist>
If the value set to false I believe my MAC should not ask for Jamf connect log in. Tested but seem to not work
