How to change a Local Admin password in JAMF pro without a script!
  • January 4, 2022
  • 9 replies
  • 932 views
Hi, we are very new to JAMF pro having recently updated from JAMF now.  We've just had to share our local admin password with a remote user and would like to now have this changed.
Can this be changed manually without any need for scripting if so how? Thanks in advance
Best answer by Danolman
Create a new policy and select the Local Accounts item. You can select the Reset Account Password item and enter the account name and new password!
  • January 4, 2022
PatrickD
  • January 5, 2022
If the local admin account you are referring to is the Jamf Management Account, you will have to use the Management Account option and select Change Account Password. Otherwise use @Danolman's solution.
PatrickD
  • January 5, 2022
Additionally, if providing the local admin account password to users is not just a 1 off, I would suggest looking at something similar to this for a Local Administrator Password Solution (LAPS).
  • January 7, 2022
Thanks a bunch @Danolman. Exactly what I needed as it resolved our request.
  • January 10, 2023
Did this end up working for you? I've tried it a few times recently, and it doesn't appear to work. When I do it, the details in the logs say "Error resetting the password for user localadmin"
NverseLab
  • January 27, 2023
Same here... confidently walked into a brick wall knowing this used to work.
NverseLab
  • January 27, 2023
I just had a duh moment.  Local accounts with SecureTokens can't be changed without supplying the old password which Jamf isn't going to implement for security reasons.  Best option (generally) is to either move away from local admin accounts or leverage a LAPS style tool.
  • October 11, 2023
what trigger should i use?
i have tried this with but it is not working
  • May 21, 2024
It didn't work for me until I added the Disable User for FileVault 2 action before the Reset Account Password. But now I'm worried about what this led to, what are the consequences of me turning off FileVault for the user
